AutoCAD 2007/2008/2009
Active Member
JONATHANKPA
Message 1 of 12 (2,244 Views)
Accepted Solution
CleanupScales.exe ERROR with AutoCAD 2008
2244 Views, 11 Replies
07-14-2011 02:22 PM
CleanupScales.exe does not work with Autocad 2008.  It used to - but now complains about missing DLLS.  After copying 2 DLLs (acdb17.dll & ac1st17.dll) to the directory where CleanupScales.exe is located, it now gives this error:"The procedure entry point ?__acHeapCreate@@YAPAVAcFixedSizeHeap@@H@Z could not be located in the dynamic link library ac1st17.dll.
How can CleanupScales be used with AutoCAD 2008?
We have a LOT of scales in our dwgs & need this to work again so we can fix it - thank you!
I finally discovered the issue - CleanupScales MUST be installed in the right directory.
When I put CleanupScales.exe (and its accompanying files) here:
C:\Program Files\AutoCAD 2008
It works.
See here:
http://autodesk.blogs.com/between_the_lines/2008/04/scale-list-clea.html
*Expert Elite*
pendean
Message 2 of 12 (2,236 Views)
Re: CleanupScales.exe ERROR with AutoCAD 2008
07-14-2011 02:41 PM in reply to: JONATHANKPA
where did the DLLs come from? What prompted you to relocate them?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
JONATHANKPA
Message 3 of 12 (2,231 Views)
07-14-2011 02:47 PM in reply to: pendean
Thanks for the help -
The DLL acdb17.dll came from here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7450124&linkID=9240618
The DLL ac1st17.dll came from here:
C:\Program Files\Common Files\Autodesk Shared\AcDwgFilter
I did not relocate the files.
I COPIED the files, because when I first ran CleanupScales.exe, it could not find those DLLs.
Why does it not work?
*Expert Elite*
pendean
Message 4 of 12 (2,226 Views)
07-14-2011 02:57 PM in reply to: JONATHANKPA
On the page your Link goes to, on the far right, are lists of AutoCAD versions for that DLL: no 2008 variant is listed.
Did anyone tell you that was a fix for this problem, or did you find the link and do it on your own? DLLs tend to be application specific, not global, or retro-active as in this case.
Have you tried to simply re-download the CleanUp utility and reinstalling it?
Active Member
JONATHANKPA
Message 5 of 12 (2,219 Views)
07-14-2011 03:00 PM in reply to: pendean
I found the link on my own...
CleanupScales.exe is listed for use w/ AutoCad 2008
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11062617&linkID=9240618
Hmm....
Active Member
JONATHANKPA
Message 6 of 12 (2,216 Views)
07-14-2011 03:05 PM in reply to: pendean
Yes - I re-downloaded the Cleanup utility & reinstalled it - no success.
Acutally, it worked on an older PC I had for Autocad 2008.  But when I got a new PC with Autocad 2008, and installed CleanupScales again, this is what occurred.
*Expert Elite*
pendean
Message 7 of 12 (2,166 Views)
07-16-2011 08:46 PM in reply to: JONATHANKPA
So the problem is Windows: WIn7 by chance?
Why not create a LISP Startup to do what you want, works well for many.
Active Member
JONATHANKPA
Message 8 of 12 (2,141 Views)
07-18-2011 05:44 AM in reply to: pendean
I have the same version of Windows as I had before, and it worked then (Windows XP).  So the problem is not Windows.
How could I create a LISP Startup to make CleanupScales.exe work?
Does anyone else use CleanupScales successfully with Autocad 2008?
Thanks!
*Expert Elite*
pendean
Message 9 of 12 (2,138 Views)
07-18-2011 06:07 AM in reply to: JONATHANKPA
Well, you don't use the external troublesome app, it is the problem after all or is that not what we are talking about? you use
-SCALELISTEDIT command (note the dash in the name) with the RESET option. Try it at the command line first and see how it works, explore the command in HELP too.
Explore peer support on the topic here:
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=Board%3A247&q=s...
Active Member
JONATHANKPA
Message 10 of 12 (2,133 Views)
07-18-2011 06:10 AM in reply to: pendean
Thank you - I've used the ScaleListEdit command a lot.  But it is not practical for large projects.  The CleanupScales.exe application is great for large #'s of files - each with many Xrefs.
Does anyone else have any suggestions for getting CleanupScales.exe to work with AutoCAD 2008?
Thanks!
Post to the Community
New Post
Need installation help?
