AutoCAD 2007/2008/2009
Valued Contributor
0 Kudos
Post 1 of 4
Circle with 3 tangents
517 Views, 3 Replies
02-24-2011 06:34 AM
I have been away from Autocad for a bit. I used to be able to draw a circle that was tangent to 3 lines, and it would automatically drop the circle in with the correct radius. Does anyone know how to do this? I can't recall if I had a lisp routine for it or if it was a standard command. Thanks in advance
*Expert Elite*
594 Kudos
Post 2 of 4
Re: Circle with 3 tangents
02-24-2011 07:07 AM in reply to: Thoisington
Command: AI_CIRCTAN
*Pro
29 Kudos
Post 3 of 4
02-24-2011 09:19 AM in reply to: Patchy
I can do it the long way, but don't you have the option in your ribbon? I know it's there for 2010 and newer...
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
*Expert Elite*
2,122 Kudos
Post 4 of 4
02-27-2011 11:32 AM in reply to: Thoisington
From the drop down menu - see attached
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Post to the Community
New Post
