In the past I used acad extensively, I still use it occasionally but it has been a while since I worked on a large scale project. Anyhow I am experiencing a wierd problem I have never seen or heard of and cant find a solution.
Once a layer is set to either yellow or magenta I canot change the layer color again. I am setting these colors using the LPM dialog. it doesent matter if its an old drawing or a brandnew one. I have tried starting from various templates everything has the same problem.
I can change the objects color manually in properties but thats horible practice and a pian.
I can change between all other colors no problem but once it goes to yellow or magenta its locked there.
what on earth would do this?
never heard/read about such an issue. It's especially hard to believe that this depends on specific 2 colors.
Can you describe detailed what happens with every click, so after opening the layer manager you click onto the icon in the color column, does that open then the color selection dialog? If so when you click then onto e.g. color 10, does the value (on the botton textbox in the dialog) change to 10 or not? ... describe it step by step what you are doing and what the dialogs show then.
And if it's possible to upload one of those drawings you have set the layer-color and can't remodify it then.
BTW: do you have any application on top of AutoCAD installed? Or any tool?
- alfred -
Hello
Welcome to the Autodesk/AutoCAD Forums !
+1 with Alfred
Q1) Which ACAD exactly ?
Q2) 32 or 64 bits
Q3) Which Windows ?
Q4) Which Service Pack already installed (if any !?) ?
Please can you give us (in .ZIP format please) your DWG or an extract ?
Bye, Pat
Patrice BRAUD
I have the same problem
Q1) Autocad 2007
Q2) 32 bits
Q3) Windows 7 professional
Q4) SP 1
thanks!!!
