AutoCAD 2007/2008/2009
Active Member
toiserkany
Message 1 of 5 (907 Views)
calculate the three-dimensional surface by autocad 2007
907 Views, 4 Replies
11-11-2012 02:55 AM
How to calculate the three-dimensional surface of a revolved arch by autocad 2007? such as an irreular dome
Which software can do the job? Autocad or Matlab software or .....
Additional Details
a three-dimensional surface is defined by 3 parameter such as x^3+2y^2-5z^3=0
Life is beautiful
The feeling is always stunned!
JDMather
Message 2 of 5 (878 Views)
Re: calculate the three-dimensional surface by autocad 2007
11-13-2012 03:22 PM in reply to: toiserkany
Something like this?  I am confused by your terms surface and solid and never really mentioned the word area.
Also the axis of rotation was not connected to your arc in your image?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
toiserkany
Message 3 of 5 (862 Views)
Re: calculate the three-dimensional (3D) surface area by autocad 2007 or Later
11-13-2012 11:46 PM in reply to: JDMather
thanks alot : totally , the position of the rotation axis is not important . My  main purpose is , calculating the outer area of a dome surface , which is made  when an arc revolved around an axis in 3D space.
Life is beautiful
Active Member
xboxphili
Message 4 of 5 (836 Views)
11-16-2012 06:18 AM in reply to: toiserkany
Perhpas my approach isn't as accurate as you might like but...
I modeled the dome and used solidedit to shell the solid, removing the bottom face and entering a really thin wall thickness. I used massprop to get the volume and divided that value by 2
Active Member
toiserkany
Message 5 of 5 (825 Views)
11-17-2012 02:44 AM in reply to: xboxphili
hello and thanks very much for your notice: Excuse me , but is it possible , explain more and exact?  I do not know your idea about , (shell the solid, and removing the bottom facuse mece). what do i do  exactly ?
Life is beautiful
