AutoCAD 2007/2008/2009
*Andreas
Message 1 of 3 (540 Views)
Bold Text in 'DWG to PDF.pc3'
540 Views, 2 Replies
07-03-2008 05:25 PM
Autodesk are aware that 'DWG to PDF.pc3' produces bold text when using TTF
(True Type Fonts) but the problem is not fixed in R2009 even though they
knew about it since R2007. Any chance of a patch real soon so that we can
move to using Windows fonts? Why provide us with a free to use PDF writer
only to find out it only half-does the job?
Andreas
*George Drayton
Message 2 of 3 (540 Views)
Re: Bold Text in 'DWG to PDF.pc3'
07-03-2008 07:19 PM in reply to: *Andreas
I think that it is applying a line thickness which usually defaults to
0.25mm. Can you put it in a layer with very small lineweight and make
sure that the ctb/stb doesn't override it.?
George Drayton CD-CAD Ltd Christchurch New Zealand
*Andreas
Message 3 of 3 (540 Views)
07-06-2008 01:24 AM in reply to: *Andreas
Thanks you George.
Haven't given this a go as yet but sounds logical. However a little
impractical if it doesn't fit in with ones STB/CTB system.
Regards
Andreas
"George Drayton" wrote in message
news:5973503@discussion.autodesk.com...
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
