AutoCAD 2007/2008/2009
Active Member
richardnoggin
Message 1 of 2 (911 Views)
Block Attributes, Text Styles, and Globally Edit
911 Views, 1 Replies
10-05-2012 09:16 AM
I have a flow diagram drawing that contains many type of blocks such as valves, transmitters, pumps, motors, tanks, gages, etc, etc, etc.  Each of these different blocks have many attributes like manufacturer, product, spec, etc, etc, etc.  All of the attributes are using the same text style called "TAG".  Currently the text style called "TAG" has a text height of 7/64".  When I increase the hieght to 1/8" the attributes remain at 7/64".
How can I globally update all the attributes to the new height of 1/8"?
I tried commands such as BATTMAN, ATTSYNC, REFEDIT, BEDIT, ATTREDEF, GATTE, and EATTEDIT but each of these commands would required me to step thru all the blocks.
It seems like one should be able to edit the style and update.
Thanks In Advance for any help...
3wood
Message 2 of 2 (864 Views)
Re: Block Attributes, Text Styles, and Globally Edit
10-06-2012 06:04 PM in reply to: richardnoggin
Please try attached file.
Command ATTSYNCALL after load it in AutoCAD.
