AutoCAD 2007/2008/2009
Active Contributor
jasonq
Message 1 of 6 (185 Views)
autostack after the case
185 Views, 5 Replies
02-13-2007 08:21 AM
Is there a way to change all the stacked fractions in MTEXT to unstacked via a lisp or a setvar or something? I know how to do weach one manually but what a waste of time if there is a global way to selct all MTEXT and run a command to unstack items that are stacked. Thanks in advance
Valued Contributor
scluckey
Message 2 of 6 (185 Views)
Re: autostack after the case
02-13-2007 01:39 PM in reply to: jasonq
I do not know about a global fix, however I do know that if you select the text (mtextedit) high light the stacked entity right click and select un stack.
Seth Cluckey
Cad Operator
Active Contributor
jasonq
Message 3 of 6 (185 Views)
02-13-2007 01:43 PM in reply to: jasonq
Thanks. I knew that way. I was hoping there was a way to change all the staked ones in a drawing at once without having to do each one individually. thanks though
bsnyder
Message 4 of 6 (108 Views)
12-15-2011 04:25 PM in reply to: jasonq
I'm still looking for this as well.
Patchy
Message 5 of 6 (101 Views)
12-15-2011 10:05 PM in reply to: jasonq
Download STRIPMTEXT, problem will be solved in a second.
http://cadabyss.wordpress.com/2010/01/04/stripmtext-v5-0/
bsnyder
Message 6 of 6 (93 Views)
12-16-2011 12:00 PM in reply to: Patchy
Superb, thank you.
