AutoCAD 2007/2008/2009
1 Kudo
Post 1 of 5
AutoCAD LT Was Not Installed Properly
344 Views, 4 Replies
11-19-2012 09:40 AM
I've seen the "AutoCAD LT Was Not Installed Properly" error all over the board and none of the suggestions work for me.
I've done the following:
A Registry Change (on a tech article)
Repair Install of AutoCAD
Removing .NET and reload it. (he has to have .net 4x due to some applications we have here, so he can't just have the required one for AutoCAD LT 2008
Any other suggestions? I am trying to avoid a rebild.
Thanks!
Brian
*Expert Elite*
1,218 Kudos
Post 2 of 5
Re: AutoCAD LT Was Not Installed Properly
11-19-2012 09:43 AM in reply to: garak0410
is this a new installation or, if it already was working, what changed on your system?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
1 Kudo
Post 3 of 5
11-19-2012 10:10 AM in reply to: Alfred.NESWADBA
Old install...a few years...on an XP SP3 machine...
Started a few months ago but hasn't been high priority. I just did a repair install and registry repair again to see if it happens.
It normally happens when he is using a batch plot program, as it opens AutoCAD briefly to stage the drawing and then closes it.
*Expert Elite*
1,218 Kudos
Post 4 of 5
11-19-2012 11:31 AM in reply to: garak0410
What programm is this? Does the error also occure if that program is not loaded or started?
I'm not sure for LT, but if you start command _OPTIONS and go to tab "Files", is there a group for supportpaths and does this group contain any directory pointing to this plot-application? If so, does AutoCAD also crash if you remove that one path (save it before so you can add it afterwards).
- alfred -
Alfred NESWADBA
1 Kudo
Post 5 of 5
11-19-2012 11:40 AM in reply to: Alfred.NESWADBA
- alfred -
It is an old program called ScriptEaze...been using it for years and no one but him has this problem and again, it just started a few months ago. I will check what you listed her in a while...
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
