AutoCAD 2007/2008/2009
Distinguished Contributor
ccurley
Message 1 of 3 (404 Views)
autocad 3d - steel structure
404 Views, 2 Replies
01-23-2013 07:16 AM
Hi all,
i am beging to model an industrial building in 3d for a client. For the best part i have been using, presspull, extrude, union etc. to create the rising elements. I am now trying to do the steelwork, portal frames and am finding my methods slow, particularly at the union of 2 elements (say rafters). I have extruded the rafter and mirrored it to reflect the opposite side but am having a hard time deciding which is the best way to trim the overlaps. Can anyone advise with their own methods which work best? It's my first real go at a total building in 3d.
Many thanks...
*Expert Elite*
JDMather
Message 2 of 3 (388 Views)
Re: autocad 3d - steel structure
01-28-2013 04:15 AM in reply to: ccurley
I would use Slice with plane or surface....
http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%208.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
ccurley
Message 3 of 3 (381 Views)
01-28-2013 06:24 AM in reply to: JDMather
Much appreciated. After getiing 75% through my steelwork model I figured that the stick model was the way forward ok. Sweep command with the delobj var set to 0 is excellent. I could however do with a bit of guidance on your 'plane' and 'surface' suggestions....
Chris.
Announcements
Need installation help?
