AutoCAD 2007/2008/2009
Member
0 Kudos
Post 1 of 5
AUTOCAD 2009 + WINXP X64 BITS EDITION
259 Views, 4 Replies
02-01-2010 05:13 PM
Hola,
Tengo un problema grave. Resulta que tengo AUTOCAD 2009 y antes tenia windows vista de 32 bits. No tube mayores problemas pero decidí instalar windows xp de 64 bits.
Tengo las ultimas actualizaciones de windows y las ultimas versiones de framework. El problema es que una vez instalado autocad 2009 al intentar abrirlo, me envía un mensaje que dice que está mal instalado.
He buscado mucho en internet pero no logro dar con la solución.
ayuda porfavor
I have a heavy problem. It just so happens that I have AUTO-CAD 2009 and before I have Windows seen of 32 bits. I did not have bigger problems but I decided to install Windows xp of 64 bits.
I have last updates of Windows and last framework's versions. The problem is than an installed time auto-DAC 2009 to try to open it, sends a message that says that it is badly installed.
I have looked up in internet a lot but I do not manage to come upon the solution.
help me please.
*George Drayton
Post 2 of 5
Re: AUTOCAD 2009 + WINXP X64 BITS EDITION
02-05-2010 02:43 PM in reply to: johvaldes0xff
Try a Repair Install from Add/Remove Programs - AutoCAD - Change/Remove
George Drayton CD-CAD Ltd Christchurch New Zealand.
Member
0 Kudos
Post 3 of 5
02-09-2010 05:08 AM in reply to: johvaldes0xff
Well, It does not work Remove and reinstall autocad 2009.
Does any person at this forum that autocad in Windows could have run exist xp x64? Supposedly autocad 2009 works in xp x64. But I do not know anyone.
Helpme, please
Mi notebook is a hp pavilion dv4-1212la
Athlon x2 dualcore
2gb RAM
256 mb ATI HD3200
250 GB hard disk
02-09-2010 06:01 AM in reply to: johvaldes0xff
Are you installing the 64-bit version of AutoCAD?
The 32-bit version will not install on a 64-bit OS.
We have a bunch of machines with Win XP 64-bit, but we also have AutoCAD
(Architecture, actually) 64-bit working just fine on them.
If you're installing from a disc, it should have both version on it and the
proper version should install itself based on the OS. If you're installing
from a download, then you're stuck - because you can't get the 64-bit
download of 2009 anymore, only 2010.
Member
0 Kudos
Post 5 of 5
02-23-2010 03:32 AM in reply to: johvaldes0xff
Thanks Joel, I have at present the version of 32 and 64 bits in a DVD. When he begins the installation automatically the application selects the type of installation. Install the version of 64 bits correctly, since he does not let me introduce the 32-bit key only the key of 64 bits.
My autocad not yet works.
Gracias Joel, actualmente tengo la versión de 32 y 64 bits en un DVD. Cuando comienza la instalación automáticamente el programa selecciona el tipo de instalación. Instala correctamente la versión de 64 bits, ya que no me deja introducir la clave de 32 bits solo la clave de 64 bits.
Aun no funciona mi autocad
Post to the Community
New Post
