I do not what happened. All my normal tool bars are gone and I could not bring them back on my screen. The command line covers the bottom fields such SNAP, OSNAP, etc.
I could not get my older screen back.
I tried everything that I know without luck.
An early response will be highly appreciated.
Apan
And your pull-down menus exist or are they gone too?
What happens if you start command _-TOOLBAR ... LAYERS ... SHOW ==> does the layer toolbar come up?
If you have saved your customizations (profile and menu) then I would restore them, would be faster than now searching for the reason why that happened.
- alfred -
Everything is working fine except i have to use contrl 9 to open command line. When command line opens - it covers the bottom tool bars that contains paper, model, snap, etc. So I work with command line off and On.
I am sorry I did nor respond earlier. I was under the gun a quite a bit. It is frustrating, however, I could work. It will be nice if this trouble goes away.
