I have inserted a block and now my origival paper space and the block both vanished. I used zii=oom realtime to look for the drawing and the block without luck. I remember I had the similar situation in the past. I had to keep on pressing a key to locate the inserted the block. I cannot remeber what key I had to press to get back to my page.
Thanks for the help.
Solved by Patchy. Go to Solution.
I have tried that and I see two blue squares. As soon as I try to zoom in - the patches disappear. I need to delete the extra blocks so that when I zoom all or extent I have the full screen.
Is there a setting in my Tools / option that needs to be changed?
Thanks.
