I am trying to create large ETransmit file containing 79 sheets. The intent is when unzip this big file - all xrefes will be in one folder. I am trying this for a while and it seems the process is hanging up on me. Is it possible to create a small E transmit file and then drag other drawings to add this zip file. Will this achieve the same intent?
Solved by pendean. Go to Solution.
I checked the file tab and I do not have those files. I can create an Etransmit file from a single file. Now I am running a combined file about ten minutes. I have repaired my AutoCAd, and also re-installed AutoCAd in maintenance mode without luck. Twice it gave me a Fatal error message.
It eventually made a Etransmit file. It took a while to form the Package. Three rimes it gave unheralded Fatal Error and crashed. I did send the error report to Autodesk. I did not get any response from them.
Yes, I am sending these drawing package to another company.for their submission. The package is about 40 MEG,
Many thanks for your effort to help me.
