AutoCAD Forum
Autocad 2008 windows vista launch error
2 REPLIES 2
CarwashMan
437 Views, 2 Replies
Fresh install of Windows Vista and Autocad 2008 no install errors but when trying to launch it shows Verifying license and then a window comes up saying "AutoCad Application has stopped working
a problem caused the program to stop working correctly, Windows will close the program and notify you if a solution is available.  CLOSE THE PROGRAM is the only option.  Event logs show mshtml.dll error."
Tried uninstalling and reinstalling, pulled off domain and tried as workgroup PC with local admin rights, added back to domain and tried again as domain admin and all come up with the same error.
Thanks for any input.
2 REPLIES 2
CarwashMan
in reply to: CarwashMan
Problem Solved, Interent Explorer issue.  Uninstalled internet explorer 9 and 8 and then it succeeded (not sure which one was the culprit) We will see if it contiues to function as I put Internet Explorer back in. Hope this helps some of the other Autocad Application has stopped issues Ive seen here.
CarwashMan
Internet Explorer back to 9 and still functions normal.  Hope this helps someon else.
”Boost
