AutoCAD 2007/2008/2009
remymerm
Message 1 of 10 (3,193 Views)
All Toolbars, Commands and Pull down Menus Missing
3193 Views, 9 Replies
11-29-2012 03:04 PM
Today when I came into my office I started using AutoCAD 2007 and it was working perfectly fine. I didnt change any settings, or anything. I hardly even did anything in the drawing except save it. I then had to restart my computer for another reason unrealted to AutoCAD, and when I restarted it and restarted AutoCAD all the Pulldown menus except for File, Help, View and Edit were missing, and all the toolbars and commands were missing. I have attached a picture of what is not missing otherwise. I tried selecting "Toolbars" in the View Pulldown menu and nothing changed. I tried opening other drawings, to no avail. I then restarted AutoCAD 4 times running it as Admin each time as I always do (It doesnt work unless running as Admin). This also didnt work. I restarted my computer 4 times to and 4 more times restarted AutoCAD. Nothing Worked. I tried a System Restore to Monday when I know it was working fine and it said that it couldnt restore it to that point. I tried a couple of other points and nothing worked. I am the only one who uses this computer, except for someone who looked at my drawings this morning for something. Everybody in the office said they didnt touch anything, and the computer was idle for 3 days.
Any Ideas? I need to get this back up and running because I need to finish this drawing to submit it. No other computers in my office are available for me to work on at the moment.
Thanks very much.
~Remy
scot-65
Message 2 of 10 (3,190 Views)
Re: All Toolbars, Commands and Pull down Menus Missing
11-29-2012 03:35 PM in reply to: remymerm
Open AutoCAD.
Command: CUI
Look in the top-left pane.
Expand Workspaces.
Highlight the desired Workspace, right-click, and select "Make Current".
Select the "Apply" button.
Select the OK button.
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
remymerm
Message 3 of 10 (3,186 Views)
11-29-2012 04:44 PM in reply to: scot-65
I will try that. Thanks! Remy Mermelstein Architect Intern. DeltaVa 767-300 Cpt. 1(914)-336-1802
remymerm
Message 4 of 10 (3,174 Views)
12-03-2012 01:47 PM in reply to: scot-65
Ok, so when I did as you said in your post I got this message: The CUI File you are attempting to open is invalid. Select a different CUI File and try again.
It opened a different CUI file where there was nothing to expand. Any Ideas?
~Remy
Member
fastdesignservices
Message 5 of 10 (3,097 Views)
02-08-2013 04:14 PM in reply to: remymerm
So what was the fix for this?  I have the same problem.  And all my CUI settings reset everytime I restart AutoCAD.  Even without a computer reboot the settings reset.  I've even tried saving the CUI settings to different drives and folders but opening them doesn't work.  I've reinstalled Cad like 5 times too.  I get a DLL error message that isn't specific, but I noticed it tends to happen whenever I mess with the CUI settings.
Thanks for help!
J
Alfred.NESWADBA
Message 6 of 10 (3,091 Views)
02-09-2013 02:10 AM in reply to: fastdesignservices
Then you don't have enough permissions to save the state when you closed AutoCAD last time.
Try to get full admin rights.
Another try would be to login to Windows with another user-account and try it again.
BTW: What os do you have?
- alfred -
Alfred NESWADBA
Member
fastdesignservices
Message 7 of 10 (3,089 Views)
02-09-2013 08:07 AM in reply to: Alfred.NESWADBA
I’m administrator on my computer. I’m the only user. I’m using windows XP Pro. I recently had a corrupt harddrive. I got a new one installed with a fresh OS installed and reinstalled AutoCAD after the windows updates. I’ve never had a problem with this before. All my other programs are working per usual. Only AutoCAD is giving me fits! Thanks. Jenn
Alfred.NESWADBA
Message 8 of 10 (3,087 Views)
02-09-2013 09:24 AM in reply to: fastdesignservices
and that:
- alfred -
Alfred NESWADBA
scot-65
Message 9 of 10 (3,078 Views)
02-11-2013 03:27 PM in reply to: remymerm
~Remy
Look in the support folder (or wherever you keep your CUI) and look at the file size.
If it is less than 100k, it kaput. Can't use that one (inherent with '07's). Select another one.
Scot-65
Member
fastdesignservices
Message 10 of 10 (3,066 Views)
02-12-2013 05:09 PM in reply to: scot-65
Here is what I found. And my interesting, just not informative Error message. J
