AutoCAD Forum
Showing results forĀ
Did you mean:Ā
about creating new layers.
3 REPLIES 3
725 Views, 3 Replies
good day Sir!
i just would like to ask something thats been bugging me out for days. .
its about creating new layers.
i created a new layer, checked it and closed layer properties manager.
but my new layer doesn't show when i open the layers again. .
i had no choice but to use "0" (since its the ONLY LAYER THERE) i just change colors and linetypes.
but its a big problem when i need to turn off some parts of the drawing.
what could be the problem. (i am using AUTOCAD 2008)
with respect,
bkurapika.
3 REPLIES 3
imadHabash
Let's try to do it from command line..
Command: -LA -LAYER
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: m
If you follow previous commnad problem still there or what ?
3wood
You might click on "All Used Layers" filter accidentally.
Just click "All" above it.
in reply to: imadHabash
but when i try to delete it, nothing happens. .but this helped Smiley Happy
thank you very much. .
Autodesk Customer Advisory Groups
