AutoCAD Forum
A font is the engineering drawing (more or less)
4 REPLIES 4
DEZATEK
1366 Views, 4 Replies
I don't even have a version of AutotCad yet. But, think I can get an eary copy inexpensively.
I want to make signs. I want to create engineering drawings (2D will do) of fonts.  So, a font is the engineering drawing, or a large part of it.
How would you produce a drawing of a font in AutoCad?
I wonder if there are any apps that deal with this.
I've heard of TXTEXP. Don't know what that is. I suppose an app.
Thanks for any help forthcoming.  Rich
Tags (1)
4 REPLIES 4
DEZATEK
in reply to: DEZATEK
Oh, I see there is also t2g Text To Geometry. Compatible with AutoCad but nothing earlier than 2012.
bgingerich
So if I'm understanding you correctly... You want to take a font and "explode" that text to its geometry (lines, arcs, etc.).
Do you want to then edit the geometry these fonts and then export the geometry as a font?  AFAIK, AutoCAD is the wrong tool for that.
Or do you just want the geometry of the fonts for other purposes?
Brandon Gingerich
Patchy
T2G works with 2008 too, it needs Version 3.5 of .NET framework for it to work, not particular acad version.
DEZATEK
in reply to: Patchy
I've found a simple solution, that I would have found yesterday if I had been using my tower PC rarther than my laptop, which won't run CAD programs very well.
I chose a Text Tool in a graphics program and scaled it to the size I want by draging a corner of the text graphic.  Then I saved it as a DWG file. I then opened the file with a free Drafting program. It worked.
”Boost
