AutoCAD Forum
3D design, mating cube to connector
4 REPLIES 4
Melodee
746 Views, 4 Replies
Hi!
I have solidworks background but don't have the software availble at the moment. I need to create a cube showing a connector on the outside panel. Simple design right?! I have the connector in dwg format, and I can create a cube! Now I just need to mate the connector to the side of the cube. How can I do this in autoCAD? I am using autoCAD 2008.
Thank you for your help in advance!
4 REPLIES 4
Patchy
in reply to: Melodee
Try UNION command
JDMather
I think you might try the align or 3Dalign (or is it align3D?) commands.
Move might be another option.
There are no assembly constraints in AutoCAD.
Melodee
in reply to: Patchy
That looks usful. First I need to align it though. I been playing around with the align feature but haven't got it to align yet. The connector I am inserting either as a block or DWG reference in to my cube drawing. I'm trying to grab the plane on the connector that mates with the cube panel side, align those places. I'm not able to grab it though!...
Patchy
Can you attach your drawings?
”Boost
