AutoCAD 2007/2008/2009
Active Contributor
karen.mitchell
Message 11 of 19 (893 Views)
Re: 2009 crashes when Layer Properties clicked
02-25-2009 12:52 PM in reply to: CADTutor62
I was having the same problem. I don't know the cause or the "real" fix but try clicking "ignore". As soon as I clicked that instead of "abort" or "retry", my layer manager reverted to normal.
Karen
Edited by: Discussion_Admin on Feb 25, 2009 4:42 PM
Active Contributor
shiney
Message 12 of 19 (893 Views)
02-25-2009 12:59 PM in reply to: CADTutor62
Unfortunately, in my case, "Ignore" just loops around and returns to the same error message.
I've been in correspondence with AutoDesk, and discussions have pointed to this being a registry problem, although the exact problem or its cause have not yet been identified.
They've asked me to try a few things with regedit, but I haven't had the time to do this yet.
Member
Trigger333
Message 13 of 19 (893 Views)
03-23-2009 02:04 PM in reply to: CADTutor62
I'm curious if Mike Dickason has figured out what this problem is. I am having a similar problem - but only certain drawings. As soon as the layer properties palette is opened I get the error message. AutoCAD does not crash - but there is no way to get away from the error message without ending the task in task manager. The following is the error message I receive:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.LayerManager.LayerViewManager.UpdateFiltersAndTreeNode(FilterProxyMap proxyMap, LayerFilter layerFilter, TreeNodeCollection nodes, FilterTree filterTree)
at Autodesk.AutoCAD.LayerManager.LayerViewManager.UpdateFiltersAndTreeView(FilterTree filterTree)
at Autodesk.AutoCAD.LayerManager.LayerManagerControl.UpdateConfiguration()
at Autodesk.AutoCAD.LayerManager.LayerManagerControl.UpdateLayerManager(RestoreType eRestore, Boolean bForce)
at Autodesk.AutoCAD.LayerManager.CommandCatcher.UpdateOnIdle.OnIdle(LayerManagerControl lmc)
at Autodesk.AutoCAD.LayerManager.LayerManagerControl.Application_Idle(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Autodesk.AutoCAD.ApplicationServices.Application.raise_Idle(Object value0, EventArgs value1)
at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.2.0.0
Win32 Version: 17.2.608.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.1434
Win32 Version: 8.00.50727.1434
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.1434_none_d08b6002442c891f/msvcm80.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Windows.Forms
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
acmgd
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/acmgd.DLL
AcRibbon
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcRibbon.DLL
AdWindows
Assembly Version: 1.0.0.0
Win32 Version: 1.0.608.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AdWindows.DLL
AcRibbon.resources
Win32 Version: 17.2.56.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/en-US/AcRibbon.resources.DLL
AdWindows.resources
Win32 Version: 1.0.56.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/en-US/AdWindows.resources.DLL
acmgdinternal
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/acmgdinternal.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcWindows.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/en-US/AcWindows.resources.DLL
PresentationFramework.Aero
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AdWindowsWrapper
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AdWindowsWrapper.DLL
AcXrefUtil
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcXrefUtil.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/en-US/AcLayer.resources.DLL
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcMgdReverse
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcMgdReverse.DLL
AcInfoCenterConn
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcInfoCenterConn.DLL
AdInfoCenter
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AdInfoCenter.DLL
AdInfoCenter.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/en-US/AdInfoCenter.resources.DLL
System.Web.Services
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Autodesk.Interop.WSCommCntr1
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/Autodesk.Interop.WSCommCntr1.DLL
AcMr
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcMr.DLL
System.Runtime.Serialization
Win32 Version: 3.0.4506.648 (Winfxred.004506-0648)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AcPrevInput
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcPrevInput.DLL
AcDialogToolTips
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcDialogToolTips.DLL
AcDialogToolTips.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/en-US/AcDialogToolTips.resources.DLL
AcCommandToolTips
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202009/en-US/AcCommandToolTips.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
*Mike Dickason \(Autodesk\)
Message 14 of 19 (893 Views)
03-23-2009 08:05 PM in reply to: CADTutor62
Feel free to email me at
href="mailto:mike.dickason@autodesk.com">mike.dickason@autodesk.com
and
we'll see if we can figure out why this error is happening.
face=Arial size=2>
Mike Dickason
AutoCAD SWD
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I'm
manager. The following is the error message I receive: Application does not
support just-in-time (JIT) debugging. See the end of this message for details.
************** Exception Text ************** System.NullReferenceException:
Object reference not set to an instance of an object. at
filterTree) at
filterTree) at
filterTree) at
Autodesk.AutoCAD.LayerManager.LayerManagerControl.UpdateConfiguration() at
eRestore, Boolean bForce) at
lmc) at
sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e)
EventArgs value1) at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Loaded Assemblies ************** mscorlib Assembly Version:
2.0.0.0 Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400) CodeBase:
---------------------------------------- acdbmgd Assembly Version: 17.2.0.0
Win32 Version: 17.2.608.0 CodeBase:
---------------------------------------- msvcm80 Assembly Version:
8.0.50727.1434 Win32 Version: 8.00.50727.1434 CodeBase:
---------------------------------------- System Assembly Version: 2.0.0.0
---------------------------------------- System.Xml Assembly Version: 2.0.0.0
---------------------------------------- System.Drawing Assembly Version:
---------------------------------------- System.Windows.Forms Assembly
Version: 2.0.0.0 Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400) CodeBase:
---------------------------------------- PresentationFramework Assembly
Version: 3.0.0.0 Win32 Version: 3.0.6920.1109
(lh_tools_devdiv_wpf.071009-1109) CodeBase:
---------------------------------------- PresentationCore Assembly Version:
3.0.0.0 Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
CodeBase:
---------------------------------------- WindowsBase Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109) CodeBase:
---------------------------------------- acmgd Assembly Version: 17.2.0.0
---------------------------------------- AcRibbon Assembly Version: 17.2.0.0
---------------------------------------- AdWindows Assembly Version: 1.0.0.0
Win32 Version: 1.0.608.0 CodeBase:
---------------------------------------- AcRibbon.resources Assembly Version:
17.2.0.0 Win32 Version: 17.2.56.0 CodeBase:
---------------------------------------- AdWindows.resources Assembly Version:
1.0.0.0 Win32 Version: 1.0.56.0 CodeBase:
---------------------------------------- acmgdinternal Assembly Version:
17.2.0.0 Win32 Version: 17.2.608.0 CodeBase:
---------------------------------------- AcWindows Assembly Version: 17.2.0.0
---------------------------------------- AcWindows.resources Assembly Version:
---------------------------------------- PresentationFramework.Aero Assembly
---------------------------------------- UIAutomationProvider Assembly
---------------------------------------- AdWindowsWrapper Assembly Version:
---------------------------------------- AcXrefUtil Assembly Version: 17.2.0.0
---------------------------------------- AcLayer Assembly Version: 17.2.0.0
---------------------------------------- AcLayer.resources Assembly Version:
---------------------------------------- Accessibility Assembly Version:
---------------------------------------- AcMgdReverse Assembly Version:
---------------------------------------- AcInfoCenterConn Assembly Version:
---------------------------------------- AdInfoCenter Assembly Version:
---------------------------------------- AdInfoCenter.resources Assembly
Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase:
---------------------------------------- System.Web.Services Assembly Version:
---------------------------------------- System.Configuration Assembly
---------------------------------------- Autodesk.Interop.WSCommCntr1 Assembly
---------------------------------------- AcMr Assembly Version: 17.2.0.0 Win32
---------------------------------------- System.Runtime.Serialization Assembly
Version: 3.0.0.0 Win32 Version: 3.0.4506.648 (Winfxred.004506-0648) CodeBase:
---------------------------------------- AcPrevInput Assembly Version: 0.0.0.0
---------------------------------------- AcDialogToolTips Assembly Version:
---------------------------------------- AcDialogToolTips.resources Assembly
---------------------------------------- AcCommandToolTips Assembly Version:
---------------------------------------- AcCommandToolTips.resources Assembly
---------------------------------------- ************** JIT Debugging
************** Application does not support Windows Forms just-in-time (JIT)
information.
Active Member
anicely
Message 15 of 19 (893 Views)
06-17-2009 11:47 AM in reply to: CADTutor62
I've been having this problem for months.
I use 2008 Civil 3D. We thought we had it figured out, but then IS updated Microsoft and it started all over again. It seems to be more prevalent in the moorings. I'd be glad to have any ideas on how to fix this problem.
This happens so often that I know if autocad is going to crash by the order that the error boxes appear. Try pulling down the filter property box, sometimes this will keep it from crashing or at least give you one more command to let you save before you crash.
Member
Trigger333
Message 16 of 19 (893 Views)
06-22-2009 05:17 AM in reply to: CADTutor62
I was shown a method to fix this problem in the registry. But the registry will always reset itself. So it would need to be modified every morning when you come in. It's just a temporary fix. I personally have had to give up on AutoCAD 2009. Like yourself I needed to get stuff done, and could not be bothered with all the problems, therefore I have retreated to back to 2008. Much more stable for me.
It was Mike Dickason (from Autodesk) that gave me the info about the registry. I got a hold of him through this thread. I know this is not much help, but all I can tell you is that AutoCAD is aware of the problem and are trying to find a fix.
Active Member
anicely
Message 17 of 19 (893 Views)
06-22-2009 07:09 AM in reply to: CADTutor62
Our IS guy that has been helping me, he had me end a process through Task Manager. I can't remember what the file name was, it started with a WC_ i think, and it seemed to help if I would end this process before I picked the layer properties box. But then...................... we updated windows, and it started all over again.
He had written a routine that would remove the file every 15 min. There was still a bug in it so he wouldn't give it to me to share. Maybe I should have him check on that again.
Member
dave.gratto
Message 18 of 19 (893 Views)
06-22-2009 09:53 AM in reply to: CADTutor62
We had a similar problem. Don't know if it is the same but it is easy to try and can't hurt. We found that if you go into Control Panel - Regional and Language Options. Change the Language from English (United States) to another english say English (United Kingdom). Click Ok. Now go back in and save it back to English (United States). That will fix the .Net error that comes up when Layer Manager is selected. It worked on a similar issue we had in 2008. Hope it works.
Active Member
anicely
Message 19 of 19 (893 Views)
06-22-2009 12:15 PM in reply to: CADTutor62
Ok. Thanks I'll try that, and let you know.
