AutoCAD 2007/2008/2009
Member
0 Kudos
Post 1 of 6
2008 Civil 3D LDD label direction orientation problem
487 Views, 5 Replies
08-15-2012 09:34 AM
Typically at my company we rotate our drawing orientation under the Projects - Drawing Setup - Orientation. Rotate the drawing to a known basis of bearings. Then we label the boundary and the bearings are rotated to match the basis of bearings without having to rotate the drawing in model space. Just reciently my labels havne't been holding the orientation. So when I add a static or dynamic label the bearing reads as though my orientation is due north. BUT, when I loook at the line priperties, the bearing is correct, as it has held the orientation. Any help with this?
594 Kudos
Post 2 of 6
Re: 2008 Civil 3D LDD label direction orientation problem
08-15-2012 09:49 AM in reply to: matt
LDD2008 has a bug in labeling dynamic and static. I found out if you go to project and delete the lock, it will work for awhile and then mess up again later.
There is no fix.
Member
0 Kudos
Post 3 of 6
08-15-2012 10:01 AM in reply to: Patchy
thanks for the reply - I just installed service packs 1 and 2 and it fixed it (for now).
594 Kudos
Post 4 of 6
08-15-2012 10:29 AM in reply to: matt
Mine is patched too, but it still doing it at radom, scary to ship out drawings with this bug.
Member
0 Kudos
Post 5 of 6
08-15-2012 10:37 AM in reply to: Patchy
yeah, that becomes a major time suck when you have to QC the same lines mulitiple times. I'll keep an eye on it. We have 5 computers with 2008 LDD and no one else has this issue. Only thing is there was a guy who used to work here who originally set up the computers and network. My computer is the only one he didn't set up - I bought the computer and  installed everything since he left (plus it's Windows 7 - which means I have to run virtual XP to run anything below ACAD 2010 - and everyone else is running regular XP), so I end up with all the problems. And no one here know's anything. Fun stuff.
594 Kudos
Post 6 of 6
08-15-2012 10:44 AM in reply to: matt
I shown this bug to our Authorized Reseller, they said, oh well, it's a bug.
If this happened again, you can see if this will happen to your drawing. Right click on the line and dynamic label will label 0 degrees, but the LABEL pull down menu, will label it correctly.
