AutoCAD 2004/2005/2006
New Member
Ted K
Message 1 of 4 (93 Views)
Wrong Area measurement reported.
93 Views, 3 Replies
02-03-2006 09:35 AM
Running AD2006 but feel this is related to just vanilla ACAD2006. Looking at the 2 plines in drawing you would think that the larger outside green pline would be report larger square ft than the smaller blue pline. Clicking area, object, reports 21799 for the green line and 22626 for the blue line. The green area line completely encapsulates and surrounds the smaller blue line? Eh? I already purged it and tried the explode, and pedit to rejoin it.
Ted
*R.K. McSwain
Message 2 of 4 (93 Views)
Re: Wrong Area measurement reported.
02-03-2006 09:57 AM in reply to: Ted K
Ted K said the following on 2/3/2006 11:35 AM:
> Hello,
No error.
PEDIT your cyan polyline, then go to Edit Vertex, then next.
Look at the construction of the polyline.
R.K. McSwain
http://rkmcswain.blogspot.com
jdunleavy1
Message 3 of 4 (93 Views)
Ted
if you look at the properties of the lines, they are not closed.
If you change them to closed, you will see that the area of the Blue area becomes 21294 sqft.
When you draw your pline, do not draw the last segment, press "c". This will close the pline. Open plines will cause this type of thing frequently.
jdunleavy1
Message 4 of 4 (93 Views)
02-03-2006 10:06 AM in reply to: Ted K
note:
after you close the pline, you will see that a line will be added from your "final vertex to the initial vertex. (your pline doubles back on itself)
You will have to correct this be redrawing your pline or exploding and deleting your duplicates, then edit to create a closed pline again.
