AutoCAD 2004/2005/2006
New Member
mnitta
Message 1 of 35 (85,805 Views)
Windows 7 and AutoCAD 2006
85805 Views, 34 Replies
10-28-2009 10:34 PM
I just got a Windows 7 computer, installed my AutoCAD 2006. Got message that 2006 has known compatibility issues. The link does not turn up any pages. How do I get 2006 to work on Windows 7? I did install Service Pack 1.
Thanks, Milt
*Dean Saadallah
Message 2 of 35 (85,805 Views)
Re: Windows 7 and AutoCAD 2006
10-29-2009 06:09 AM in reply to: mnitta
If you have the correct Win7 version, you can use it's XP compatibility
option to run R2006.
Autodesk is only going to take steps to make R2010 Win7 compliant.
Dean Saadallah
http://LTisACAD.blogspot.com
New Member
mnitta
Message 3 of 35 (85,805 Views)
10-29-2009 10:21 AM in reply to: mnitta
Thanks Dean. I did get AutoCAD 2006 to run on Windows 7 in XP compatibility mode. I did not know that Windows had this mode.
I did the following: right click on the AutoCAD 2006 icon, click on "Troubleshoot compatibility", click on "Try recommended settings". You will probably get "Windows XP (Service Pack 2)". Click on "Start the Program".
Thanks again, Milt
*Dean Saadallah
Message 4 of 35 (85,805 Views)
10-29-2009 11:34 AM in reply to: mnitta
Thanks for the follow up.
XPMode showed up with Vista, continues with Win7.
Dean Saadallah
Member
Procent
Message 5 of 35 (85,805 Views)
12-18-2009 02:39 PM in reply to: mnitta
Try to run Autocad 2006 using XP service pack 2 mode but still wont fire up any suggestion
New Member
kozakvod
Message 6 of 35 (85,805 Views)
12-30-2009 06:28 PM in reply to: mnitta
Dean or ANYONE....HELP!!!
Okay I recently HAD to upgrade from XP to Windows 7. Knowing that I would have to reinstall all programs, I took the plunge and now GRRRR!
I first installed ADT 2006, wouldn't open at all. Then I found this thread about the XP compatibility so I removed the program and everything concerning it and reinstalled. Still wouldn't open as it was looking for these specific dll files. I then went to the compatibility option and it opened, sorta. It did say THIS PROGRAM HAS KNOWN COMPATIBILITY ISSUES.
So continueing on...it opened up and then immediately told me that the customization file 'ADT.cui' failed to load. I hit okay and it continued loading.
After loading, I noticed that all of my tool bars, etc. across the top that I always previously had are not there, further, the main menu bar was reduced to File, View, Window, Help is all there is. There is no right click available, no nothing.
What do I do? I can't believe that Autodesk is going to leave us hung out to dry.
Help please!!!!
Jeff
*Rowland
Message 7 of 35 (85,806 Views)
12-31-2009 05:28 AM in reply to: mnitta
I don't why you expect Autodesk to support Acad 2006 in Windows 7...not
going to happen.
As for your error and missing menus, try the menuload command and browse
to where ever adt.cui is located and load that.
That might bring back your missing toolbars/menus.
New Member
sharon1111
Message 8 of 35 (85,805 Views)
02-09-2010 11:17 AM in reply to: mnitta
Thanks. I had the same problem and I had to search for those menus and they came up. You have to find the right path, though which wasn't easy. Anyhow, my only problem is that I wasn't able to install the service pack. It keeps saying the following:
"The service pack could not be installed because the expected Autodesk product could not be located on your computer. Make sure that you are using the correct service pack for the product."
Any ideas on how to fix that?
New Member
jfrhodes
Message 9 of 35 (83,932 Views)
07-14-2010 06:00 AM in reply to: mnitta
Hello all,
I have downloaded Autocad 2006 into Windows 7 using xp mode.  It works but the drafting selection crosshair is superimposed with the typical mouse pointer of windows.  The crosshair follows the mouse pointer.  Any words of advice or suggestions?
thank you
New Member
BobWard1
Message 10 of 35 (83,499 Views)
07-22-2010 02:52 PM in reply to: jfrhodes
jfrhodes,
I just ran into the exact same problem.  Installed AutoCAD 2006 under Virtual XP mode on my Windows 7 computer, opened AutoCAD and the mouse pointer follows the cross-hairs.
This happens with both my Logitec mouse and the Touchpad on the computer.
Hopefully someone has a solution.
Bob
