AutoCAD 2004/2005/2006
Distinguished Contributor
0 Kudos
Post 1 of 7
Using AutoCAD with two monitors
253 Views, 6 Replies
07-07-2006 11:02 AM
I have been trying to figure out how to make my AutoCAD use two monitors in one drawing. I have two monitors now, and it allows me to use only one for the AutoCAD application leaving the 2nd open for other applications. Pretty much I just want to see my drawing on both screens...does anyone know how I can change this? Is there a setting I can switch on/off for it? I'd appreciate any suggestions..Thanks and happy drawing!
Re: Using AutoCAD with two monitors
07-07-2006 01:22 PM in reply to: cadpro78
Normalize your AutoCAD and then drag the edges where you want. This works
with every program I have tried.
Brad
wrote in message news:5230472@discussion.autodesk.com...
07-09-2006 03:30 PM in reply to: cadpro78
just curious. why do you want to see your dwg in both monitirs??
I have 2 monitors as well and I usually start up another session of Autocad
where I work on the xref's . Or maybe have the detail drawing on one screen
and plan/elevations on the other.
Jonas
*Daniel Bennett
Post 4 of 7
07-09-2006 09:16 PM in reply to: cadpro78
I do. I use the Nvida card and had to update the driver from the net. Once
you have the drivers installed simply bring up your Display Properties >
Settings > Advanced > Graphics card screen and set your monitor to
"Daulview". (Attachment 1) You can do Span as well but it is not as
flexible. Then scroll down to user Interface and select "Full Desktop
Maximize". (Attachment 2) And your done. Of course if it's not a Nvidia
based card it will be a different story.
Daniel
0 Kudos
Post 5 of 7
07-10-2006 05:19 AM in reply to: cadpro78
Thanks Jonas! That is a great idea you just gave me. Thanks for the suggestion.
3 Kudos
Post 6 of 7
07-10-2006 07:54 AM in reply to: cadpro78
First thing to verify is that your graphics card will support more than one monitor.
0 Kudos
Post 7 of 7
07-10-2006 08:00 AM in reply to: cadpro78
my graphics card does support more than one monitor...everyone else in the office is able to do so, so I would think mine would too.
Post to the Community
New Post
