AutoCAD 2004/2005/2006
Member
0 Kudos
Post 1 of 6
turn off Mouse scroll button zoom.
705 Views, 5 Replies
06-29-2005 08:11 PM
How do I turn OFF the “scroll button zoom”? Change it to scrolling like with ms word.
*Tracy Lincoln
Post 2 of 6
Re: turn off Mouse scroll button zoom.
07-01-2005 06:50 PM in reply to: lewist76
Doesn't work that way... That is a PAN (which you can do by holding down the
scroll wheel (middle button)) or use the scroll bars. You can hold down the
middle buton and either SHIFT key to confine the PAN to only verticle or
horizontal movement. You can also still use the old -PAN command with your
ORTHO on.
Tracy Lincoln - TLConsulting
http://TLConsulting.blogspot.com/
Consulting, Design & Training Specialist
Autodesk Discussion Group Facilitator
http://discussion.autodesk.com/
wrote in message news:4889311@discussion.autodesk.com...
How do I turn OFF the "scroll button zoom"? Change it to scrolling like with
ms word.
Member
0 Kudos
Post 3 of 6
07-05-2005 10:39 AM in reply to: lewist76
that was not the question. I know there must be a setting somewhere that changes the zoom function back to scrolling down and up on the drawing.
Valued Contributor
0 Kudos
Post 4 of 6
07-05-2005 10:07 PM in reply to: lewist76
Well I have the opposite problem. I want to zoomand not scroll up and down. It only works in 3D-ORBIT.
Perhaps we could change computers? ;-)
Cheers!
Active Member
0 Kudos
Post 5 of 6
07-06-2005 01:28 AM in reply to: lewist76
MBUTTONPAN, change setting to1 or 0 depending on what comes up. Same process to go back.
Valued Contributor
0 Kudos
Post 6 of 6
07-06-2005 02:40 AM in reply to: lewist76
Well, that command only turns on/off the pan command and I dont think we want that.
Cheers!
Post to the Community
New Post
