AutoCAD 2004/2005/2006
Distinguished Contributor
sports7
Message 1 of 7 (582 Views)
Steel Member Shapes?
582 Views, 6 Replies
09-13-2011 09:53 AM
Im looking for something that will insert different steel member shapes like W shapes, S shapes angles ect.  We use to have a program called Steel Plus that did this but we cant seem to get the program anymore.  Is there anything out there that will do this?
Valued Mentor
KLYPHY
Message 2 of 7 (569 Views)
Re: Steel Member Shapes?
09-14-2011 06:59 AM in reply to: sports7
I like this one. After loading, just type "stl".
I'm not a programmer, so I don't know if the .dcl file is needed to run the .lsp file, but I sent it also.
Good Luck -KLYPH
JDMather
Message 3 of 7 (550 Views)
10-20-2011 03:57 PM in reply to: sports7
These shapes are built into Autodesk Inventor - Frame Generator
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Bob_Zurunkle
Message 4 of 7 (542 Views)
10-21-2011 09:52 AM in reply to: sports7
OP you could create your own n a container drawing, by referencing the Steel Manual. Then you could link them to tool palettes...
Doesn't 2006 have dynamic blocks? you could do a DynBlk version of what I did, and separate the blocks into all W6s, all w8s etc. good luck! :smileyhappy:
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Valued Mentor
KLYPHY
Message 5 of 7 (531 Views)
10-24-2011 03:11 PM in reply to: Bob_Zurunkle
I couldn't find any steel shapes in my 2007 Release.
We used to have them, but they offered sizes in Depth x Width x Weight.
Our Engineer has Steel sizes that come with only Depth x Weight.
So, we didn't use the AutoCAD shapes.
My 2011 Release has a nice Dynamic Steel shape.
But, while it does have 16 depths, it has only 41 WF sizes.
The actual block does not have the Flange/Web joint filletted.
The STL lisp offers 17 Depths for a total of 299 sizes.
AND the joint is filletted.
I'm still hoping that AutoCAD 2012 offers more.
We'll see.
Read Y'all Later -KLYPH
Patchy
Message 6 of 7 (526 Views)
10-24-2011 08:13 PM in reply to: KLYPHY
2012 Mechanical has all Metric or ANSI steel shapes.
Bob_Zurunkle
Message 7 of 7 (508 Views)
10-26-2011 09:18 AM in reply to: Patchy
I took the steel shape DynBlk from my 2011 as a starting point, but I have my insertion point at mid-top. I also did it with constraints, which the OP doesn't have in the 2006 version, and mine not only does it with fewer constraints than the OEM version, but addresses the fillets (which the OEM doesn't). I developed an initial block for just the W8s, and then spun off the other sizes from that...
