AutoCAD 2004/2005/2006
Member
laddo
Message 1 of 8 (259 Views)
Spiral, Coil, Helix?
259 Views, 7 Replies
10-19-2004 06:21 AM
Does any body know if it's possible to and how to draw a coil i.e. spring in 3D?
*Main
Message 2 of 8 (259 Views)
Re: Spiral, Coil, Helix?
10-19-2004 06:58 AM in reply to: laddo
I think there is a routine on one of the AutoCAD site like CADALIYST if I've spelt it right or AUGI etc... "laddo" wrote in message news:24845697.1098192129826.JavaMail.jive@jiveforum1.autodesk.com... | Does any body know if it's possible to and how to draw a coil i.e. spring in 3D?
*Neil Markham
Message 3 of 8 (259 Views)
10-19-2004 04:13 PM in reply to: laddo
Hi Laddo, try this... http://cadtutor.net/forum/viewtopic.php?t=1463 Neil "Main" wrote in message news:41751d70$1_1@newsprd01... > I think there is a routine on one of the AutoCAD site like CADALIYST if I've > spelt it right or AUGI etc... > "laddo" wrote in message > news:24845697.1098192129826.JavaMail.jive@jiveforum1.autodesk.com... > | Does any body know if it's possible to and how to draw a coil i.e. spring > in 3D? > >
Member
laddo
Message 4 of 8 (259 Views)
10-20-2004 12:03 AM in reply to: laddo
Thanks Neil,
I've tried it an it works a treat!! You don't know of a similar lisp file that allows you to specify the pitch distance instead of the No. of turns though do you?
Darren (laddo)
Jim AU
Message 5 of 8 (259 Views)
10-20-2004 03:01 AM in reply to: laddo
Try this 'un
Member
laddo
Message 6 of 8 (259 Views)
10-20-2004 03:11 AM in reply to: laddo
Looks good but I hate to be a pain!!! I'd like to be able to draw a poly line instead of the shape produced so I can extrude an item along it's path, is that possible?
Darren
Jim AU
Message 7 of 8 (259 Views)
10-20-2004 03:20 AM in reply to: laddo
Use zero as coil width and you can use as an extrusion path
Member
laddo
Message 8 of 8 (259 Views)
10-20-2004 03:45 AM in reply to: laddo
I'll try that cheers, you are a gentleman and a scholar (no idea how to spell that but never mind engineers can't normally spell!!!)
Darren
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
