AutoCAD 2004/2005/2006
*Bruce Sheldon
Post 1 of 8
Sheet Set Association
1960 Views, 7 Replies
03-13-2006 10:25 AM
Hi all,
Is there any way to "open" a drawing, "remove association from Sheet Set",
save, close.
Simple.
Am tired of not being able to add drawings to a new Sheet Set. A PITA.
Bruce
*Jimmy Bergmark
Post 2 of 8
Re: Sheet Set Association
03-13-2006 10:38 AM in reply to: *Bruce Sheldon
http://jtbworld.blogspot.com/2005/10/remove-sheet-set-association-on-sheet.html
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) - http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
"Bruce Sheldon" wrote in message
news:5109412@discussion.autodesk.com...
Hi all,
save, close.
Simple.
Bruce
*Tim Decker
Post 3 of 8
03-13-2006 10:40 AM in reply to: *Bruce Sheldon
Normally if you try to import a drawing into a new sheet set, it will
give you the option of removing the drawing from a previous sheet set,
if it was part of a prior set.
You can also just right click on a drawings existing sheet set entry,
and it gives you an option to remove it from it's current set.
SSLOCATE set to 1 will automatically open an associated sheet set if a
drawing has one, to make it easy to "remove" it, if you don't know
which sheet set it might be part of.
Bruce Sheldon wrote:
> Hi all,
> Set", save, close.
> Simple.
> PITA.
> Bruce
*Bruce Sheldon
Post 4 of 8
03-13-2006 11:15 AM in reply to: *Bruce Sheldon
Tim,
Thanks for the reply.
Doesn't really answer my question, though.
Let me explain.
* I want to remove a drawing from any association to a Sheet Set.
* I don't want to even so much as see the Sheet Set (assume it's on the
other side of the world).
* I don't want to see the "script blocker" dialog box that asks if you want
to remove, etc...
* I want to script a whole bunch of DWGs, delete any and all Sheet Set
associations from them.
"Tim Decker" wrote in
message news:5109444@discussion.autodesk.com...
> Hi all,
> Set", save, close.
> Simple.
> PITA.
> Bruce
*Tim Decker
Post 5 of 8
03-13-2006 11:25 AM in reply to: *Bruce Sheldon
From Jimmy's post above, the blog he points to says that the following
code, that can be run in a script file (so it can be done to multiple
drawings) can do the trick. I have not tested this though.
fileopen "x:\drawings\drawing1.dwg"
(dictremove (namedobjdict) "AcSheetSetData")
qsave
fileopen "x:\drawings\drawing2...
and so on.
> Tim,
> Let me explain.
> the other side of the world).
> you want to remove, etc...
> Set associations from them.
*Bruce Sheldon
Post 6 of 8
03-13-2006 12:26 PM in reply to: *Bruce Sheldon
Tim,
The LISP command looks like it does the job.
Anyone know how to stop the dialog box from coming up?
I'm talking about version 2005 since 2006 automatically removes
associations.
I'm running 2005 on one machine and 2006 on another. I can do the script on
my 2006 machine, but would be nice to know how to stop the dialog on 2005.
Thanks a lot everyone!
message news:5109514@discussion.autodesk.com...
qsave
and so on.
> Tim,
> Let me explain.
*Jimmy Bergmark
Post 7 of 8
03-13-2006 12:41 PM in reply to: *Bruce Sheldon
If you run the script with SmartPurger it automatically stops dialog boxes
like this one.
news:5109623@discussion.autodesk.com...
Tim,
associations.
*Bruce Sheldon
Post 8 of 8
03-14-2006 08:49 AM in reply to: *Bruce Sheldon
Thanks, Jimmy, I will look into this.
"Jimmy Bergmark" wrote in message
news:5109640@discussion.autodesk.com...
like this one.
Tim,
associations.
