AutoCAD 2004/2005/2006
1 Kudo
Post 1 of 4
select file dialog box
541 Views, 3 Replies
04-22-2005 02:42 AM
When I select open files, I get the thumbnails view in the select file
dialog window as default. When I switch to details view, it switches back to thumbnails view every time I select a (sub)folder.
I'm using AutoCAD 2004 with Windows XP SP2 in a Windows Server based environment. The problem does not appear in other programs.
Does anyone know how to change the default appearance to be details view? I expect it has something to do with user-rights.?
*R.K. McSwain
Post 2 of 4
Re: select file dialog box
04-22-2005 05:00 AM in reply to: hanshgmb
> file dialog window as default. When I switch to details view, it
> environment. The problem does not appear in other programs. Does
Have you looked at these yet?
http://usa.autodesk.com/getdoc/id=TS71052
http://usa.autodesk.com/getdoc/id=TS70062
Active Member
0 Kudos
Post 3 of 4
03-09-2009 09:53 AM in reply to: hanshgmb
I have the same problem as hanshgmb. It has nothing to do with folder settings from Windows. It is an AutoCAD bug. Other program don't have this problem. When I go to AutoCAD and try to open a file by going to "file", "open", the view in the explorer window remains in thumbnail view. When I navigate back and forth in the explorer window it reverts back to thumbnail view everytime even after I change it to list or detail view. Do you know of a hotfix for this?
New Member
0 Kudos
Post 4 of 4
08-12-2010 12:03 PM in reply to: picasullivan.com
Has anyone found a fix for this? I am having the same problems with AutoCAD 2007 Land Map & running on Windows 7.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
