AutoCAD 2004/2005/2006
Bob_Zurunkle
Message 11 of 14 (2,083 Views)
Re: Rotate Dimension Text
04-19-2011 10:00 AM in reply to: Ferreras_04
Oh, if you have an Inventor question, you should be posting specifically in the Inventor forums :smileyhappy:
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
New Member
raiarchitect
Message 12 of 14 (2,074 Views)
04-26-2011 09:37 AM in reply to: macha_p
Took me awhile to find the solution, but it works.
  1. Change dimtxtdirection to ON
  2. Change text placement vertical to BELOW
  3. Do a dimupdate
New Member
neilharper2101
Message 13 of 14 (2,008 Views)
06-08-2011 03:38 PM in reply to: macha_p
DIMEDIT can be used to rotate the text.
Very easy, no nead to redo anything
Valued Contributor
pareson
Message 14 of 14 (1,994 Views)
06-21-2011 12:04 PM in reply to: macha_p
Hi there,
here'e a lisp that rotates dim text to 180deg (attached), i got this also in another tread, hope its not too late, but somehow you can use this for the same issue later.
