AutoCAD 2004/2005/2006
0 Kudos
Post 1 of 6
Remote Text In AutoCAD2006
112 Views, 5 Replies
10-28-2005 11:06 AM
Previously I could edit my Remote Text through the Properties Center (like Height, Layer, Styles and color) now in AutoCAD 2006 when I do select the Remote Text in the drawing , the properties Dialog box does not recognize this entity, that will prevent the user from editing the remote text.
My question is this a new features in AutoCAD 2006 and if it is how I can edit my Remote Text.
Thanks Tai.B.
*melanie stone
Post 2 of 6
Re: Remote Text In AutoCAD2006
10-28-2005 11:18 AM in reply to: Tai B.
Please pardon my ignorance, but, I am unfamiliar with the term 'Remote
Text', can you explain what that is, please?
wrote in message news:4997928@discussion.autodesk.com...
Thanks Tai.B.
Distinguished Contributor
0 Kudos
Post 3 of 6
10-28-2005 11:59 AM in reply to: Tai B.
I haven't used RTEXT in a while so I just tried it and I see what you mean. It is highlighted when I pick it but it is not shown in properties.
Not sure how it is supposed to be editied.
In Express Tools help RTEXT is called Reactive Text, but Autodesk also calls it Remote Text.
*Allen Johnson
Post 4 of 6
10-28-2005 12:25 PM in reply to: Tai B.
RTEDIT
Allows you to edit existing remote text (Rtext) objects
Command: RTEDIT
Select objects: Select the Rtext object
Style: MYSTYLE Height: 0.1000, Rotation: 0
Enter an option [Style/Height/Rotation/Edit]: Specify an option
Options
Style Specifies a new style for the Rtext object.
Height Specifies a new height for the Rtext object.
Rotation Specifies a new rotation for the Rtext object.
Edit Allows you to edit the Rtext.
Exit Exits the command.
To create Rtext objects use the RTEXT command.
Note:
Use the command RTEXTAPP to assign a specific text file editor to RTEDIT.
Command line: RTEDIT
Files: rtext.lsp, rtext.arx
*melanie stone
Post 5 of 6
10-28-2005 12:41 PM in reply to: Tai B.
ah, ok! thanks.
wrote in message news:4998003@discussion.autodesk.com...
it Remote Text.
0 Kudos
Post 6 of 6
10-29-2005 09:41 AM in reply to: Tai B.
From 5 or 6 Response, you are the only one gave me the answer,
Redit it will solve the problem.
Thanks allot for all other member's responses, just to replay it is very nice; either you have the answer or no. I do appreciate any replay.
But folks do you agree that AutoCAD 2006 not recognizing the Rtext in the properties dialog box is (kind of error or problem in this revision)
Thanks aging for all
Post to the Community
New Post
