AutoCAD 2004/2005/2006
Distinguished Contributor
anim8er
Message 1 of 4 (196 Views)
Quantize command for drawings?
196 Views, 3 Replies
02-29-2008 09:21 AM
I'm looking for a LISP command that will Quantize objects in a drawing file to a specified amount. I'm working in drawings that should have been drawn with SNAP on, but were not. I would like a command that will take every line and polyline vertex, block insertion point etc... and place them on the snap coordinates. I found a discussion here for such a thing, but the LISP routine was no longer attached to the messages.
New Member
chris4d000
Message 2 of 4 (147 Views)
Re: Quantize command for drawings?
10-06-2011 09:44 AM in reply to: anim8er
did you ever get a response on this?  I'm looking for the same thing.  Thanks --
*Expert Elite*
azrdgldr
Message 3 of 4 (143 Views)
10-06-2011 10:05 AM in reply to: chris4d000
Do a google search for such a command or search the Lisp/Vlisp forum to see if a program all ready exists or post a request there, if you peak someone's interest they may write one for you.
Active Contributor
3dwannab
Message 4 of 4 (70 Views)
05-27-2014 09:53 AM in reply to: azrdgldr
I know this is quite late but here's one for anyone interested still. It was not wrote by me, but by David Forbus.
I just fixed the script so that it calls back the OSNAP settings where it didn't before.
;;; QUANTALL
;;; Written by David Forbus 09_dec_2008
;;; QUANTALL prompts a user for a Quantize Value
;;; QUANTALL then prompts a user for a selection set and then
;;; modifies the INSERTION POINTS of TEXT, MTEXT, CIRCLES, BLOCKS, LINES and LWPOLYLINES within that selection set so they all "snap" to quantized coordinates.
(defun QUANTLN ()
(setq SP-X (/ (cadr (assoc 10 CURENT)) QUANT-VALUE ))
(setq SP-Y (/ (caddr (assoc 10 CURENT)) QUANT-VALUE ))
(setq SP-Z (/ (cadddr (assoc 10 CURENT)) QUANT-VALUE ))
(setq EP-X (/ (cadr (assoc 11 CURENT)) QUANT-VALUE ))
(setq EP-Y (/ (caddr (assoc 11 CURENT)) QUANT-VALUE ))
(setq EP-Z (/ (cadddr (assoc 11 CURENT)) QUANT-VALUE ))
(if (>= (- SP-X (fix SP-X)) 0.5) (setq SP-X (* QUANT-VALUE (+ 1.0 (fix SP-X)))) (setq SP-X (* QUANT-VALUE (fix SP-X))))
(if (>= (- SP-Y (fix SP-Y)) 0.5) (setq SP-Y (* QUANT-VALUE (+ 1.0 (fix SP-Y)))) (setq SP-Y (* QUANT-VALUE (fix SP-Y))))
(if (>= (- SP-Z (fix SP-Z)) 0.5) (setq SP-Z (* QUANT-VALUE (+ 1.0 (fix SP-Z)))) (setq SP-Z (* QUANT-VALUE (fix SP-Z))))
(if (>= (- EP-X (fix EP-X)) 0.5) (setq EP-X (* QUANT-VALUE (+ 1.0 (fix EP-X)))) (setq EP-X (* QUANT-VALUE (fix EP-X))))
(if (>= (- EP-Y (fix EP-Y)) 0.5) (setq EP-Y (* QUANT-VALUE (+ 1.0 (fix EP-Y)))) (setq EP-Y (* QUANT-VALUE (fix EP-Y))))
(if (>= (- EP-Z (fix EP-Z)) 0.5) (setq EP-Z (* QUANT-VALUE (+ 1.0 (fix EP-Z)))) (setq EP-Z (* QUANT-VALUE (fix EP-Z))))
(setq CURENT (subst (list 10 SP-X SP-Y SP-Z) (assoc 10 CURENT) CURENT ))
(setq CURENT (subst (list 11 EP-X EP-Y EP-Z) (assoc 11 CURENT) CURENT ))
(entmod CURENT)
(defun QUANTPOLY ()
(setq COUNTER2 1)
(setq POLY-NEW (list))
(while (< COUNTER2 (length CURENT))
(setq VRTX-PNT (nth COUNTER2 CURENT))
(if (= 10 (car VRTX-PNT))
(progn
(setq SP-X (/ (cadr VRTX-PNT) QUANT-VALUE ))
(setq SP-Y (/ (caddr VRTX-PNT) QUANT-VALUE ))
(setq POLY-NEW (append POLY-NEW (list (list 10 SP-X SP-Y)))))
(if (= 330 (car VRTX-PNT)) nil (if (= 5 (car VRTX-PNT)) nil (setq POLY-NEW (append POLY-NEW (list VRTX-PNT))))
(setq COUNTER2 (+ COUNTER2 1))
(entmake POLY-NEW)
(entdel CURENT-NAME)
(defun QUANTREG ()
(entmod CURENT)
(defun QUANTXT ()
(setq TXT-HORZ (cdr (assoc 72 CURENT)))
(setq TXT-VERT (cdr (assoc 73 CURENT)))
(if (= TXT-HORZ 0)
(if (= TXT-VERT 0)
(progn
(progn (setq SP-X (/ (cadr (assoc 11 CURENT)) QUANT-VALUE ))
(setq SP-Y (/ (caddr (assoc 11 CURENT)) QUANT-VALUE ))
(setq SP-Z (/ (cadddr (assoc 11 CURENT)) QUANT-VALUE ))
(setq CURENT (subst (list 11 SP-X SP-Y SP-Z) (assoc 11 CURENT) CURENT ))
(entmod CURENT)
(defun QUANTARC ()
(setq RAD-R (/ (cdr (assoc 40 CURENT)) QUANT-VALUE ))
(if (>= (- RAD-R (fix RAD-R)) 0.5) (setq RAD-R (* QUANT-VALUE (+ 1.0 (fix RAD-R)))) (setq RAD-R (* QUANT-VALUE (fix RAD-R))))
(setq CURENT (subst (cons 40 RAD-R) (assoc 40 CURENT) CURENT ))
(entmod CURENT)
(defun c:Fix_Quantize_All ( / osnap ) ;;3dwannab fix
(setvar "cmdecho" 0)
(setq OSNAP (getvar "osmode")) ;;3dwannab fix
(setvar "osmode" 0)
(setq QUANT-VALUE (getreal "\nEnter Quantize Value: "))
(setq SELECT-SET (ssget))
(setq COUNTER0 (1- (sslength SELECT-SET )))
(while (> COUNTER0 -1.0)
(setq CURENT (entget (ssname SELECT-SET COUNTER0)))
(setq CURENT-NAME (ssname SELECT-SET COUNTER0))
(if (= (cdr (assoc 0 CURENT)) "LINE") (QUANTLN))
(if (= (cdr (assoc 0 CURENT)) "TEXT") (QUANTXT))
(if (= (cdr (assoc 0 CURENT)) "MTEXT") (QUANTREG))
(if (= (cdr (assoc 0 CURENT)) "INSERT") (QUANTREG))
(if (= (cdr (assoc 0 CURENT)) "CIRCLE") (QUANTREG))
(if (= (cdr (assoc 0 CURENT)) "ARC") (QUANTARC))
(if (= (cdr (assoc 0 CURENT)) "LWPOLYLINE") (QUANTPOLY))
(setq COUNTER0 (1- COUNTER0))
(princ)
(setvar "osmode" OSNAP)
(princ "\nType \"Fix_Quantize_All\" to Quantize the INSERTION POINTS of TEXT, MTEXT, CIRCLES, ARCs, BLOCKS, LINES and LWPOLYLINES to the round off value.")
OS: Windows 7 Ultimate x64 CPU: i7 CPU 965 @ 3.20GHz RAM: Crosair 12288 MBytes DDR3 GPU: ATI Radeon HD 4870 X2 MONITOR: 32" HP LP3065 LCD
Freelance CAD and 3d Architectural Visual Artist: stephensherry147@yahoo.co.uk
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
