AutoCAD 2004/2005/2006
Distinguished Contributor
1 Kudo
Post 1 of 8
propulate
130 Views, 7 Replies
04-07-2005 03:36 PM
When I use the PROPULATE command in 2006, it essentially makes all the field data invisible. If I add new custom fields, they will appear below the existing fields that are invisible. This appears to be a bug, but I am wondering if anybody has had the same problem and if they came up with a workaround.
Elise Moss
www.mossdesigns.com
*Tracy W. Lincoln
Post 2 of 8
Re: propulate
04-07-2005 04:03 PM in reply to: elise_moss
Is PROPULATE still an Express Tool or part of the core commands in 2006? -- Tracy W. Lincoln - TLConsulting http://TLConsulting.blogspot.com/ Consulting, Design & Training Specialist Autodesk Discussion Group Facilitator "elise_moss" wrote in message news:10666200.1112913404339.JavaMail.jive@jiveforum2.autodesk.com... > When I use the PROPULATE command in 2006, it essentially makes all the field data invisible. If I add new custom fields, they will appear below the existing fields that are invisible. This appears to be a bug, but I am wondering if anybody has had the same problem and if they came up with a workaround. > > Thanks, > > Elise Moss > www.mossdesigns.com
1 Kudo
Post 3 of 8
Re: propulate
04-07-2005 06:16 PM in reply to: elise_moss
It appeared to be a standard tool.
*Wm.J.Townsend
Post 4 of 8
Re: propulate
04-07-2005 07:09 PM in reply to: elise_moss
It went DOA with 2005. -Bill elise_moss wrote: > When I use the PROPULATE command in 2006
*Herman Mayfarth
Post 5 of 8
Re: propulate
04-07-2005 10:11 PM in reply to: elise_moss
? I've used propulate in 2K5 with success. Haven't tried it in 2K6 Always an E.T., Officially unsupported, AFAIK.
*Wm.J.Townsend
Post 6 of 8
Re: propulate
04-08-2005 01:44 AM in reply to: elise_moss
My mistake. I miswrote. It probably works as intended. The problem for me is that R2K5&6 PROPULATE truncates user comments and apparently doesn't support line feeds of any know type, and it won't populate user fields beyond the initial ten selections. I consider it a busted tool and rely on properly setup templates instead. Sorry to mislead. -Bill Herman Mayfarth wrote: > I've used propulate in 2K5 with success. > Haven't tried it in 2K6
1 Kudo
Post 7 of 8
Re: propulate
04-08-2005 08:12 AM in reply to: elise_moss
It worked great in 2005, but doesn't seem to work properly in 2006.
How can they break a perfectly good tool?
Elise Moss
www.mossdesigns.com
0 Kudos
Post 8 of 8
Re: propulate
04-08-2005 08:26 AM in reply to: elise_moss
"How can they break a perfectly good tool? "
It's what programmers do best....
