AutoCAD 2004/2005/2006
New Member
0 Kudos
Post 1 of 8
PDF import into ACAD
6040 Views, 7 Replies
09-18-2006 08:00 AM
What is the best way to import a pdf scanned drawing into AutoCAD? I know there are service providers that will convert pdf files to vector data, for a stiff fee. Is it feasible to import the pdf to an AutoCAD layer and trace over the image on another layer?
Thanks for any feedback.
*Allen Jessup
Post 2 of 8
Re: PDF import into ACAD
09-18-2006 08:18 AM in reply to: rdiercks
In Acrobat reader create a snapshot of the area you want. Bring it into a
raster program and save it as you favorite flavor of raster. Insert the
raster in to AutoCAD. Scale and rotate as needed. Do your heads-up
digitizing on the raster.
Allen
wrote in message news:5332575@discussion.autodesk.com...
Active Contributor
0 Kudos
Post 3 of 8
09-19-2006 05:08 AM in reply to: rdiercks
On a side note, its often worth checking if a pdf is still a vector before you go tracing it. Most of the time pdfs made from Acad can be converted back to Acad drawings using something like abobe illustrator. Its saved me a lot of time on more than one occasion.
*R.K. McSwain
Post 4 of 8
09-19-2006 05:16 AM in reply to: rdiercks
davefitzpatrick said the following On 9/19/2006 7:08 AM:
> illustrator.
The OP said it was a scanned PDF.
However, if it *is* vector, see
http://rkmcswain.blogspot.com/2006/03/convert-pdf-to-dwg.html for some
more options.
R.K. McSwain
Valued Contributor
9 Kudos
Post 5 of 8
08-03-2011 10:28 AM in reply to: rdiercks
I know this sounds dumb and my boss hates it, but it works.  xref a .pdf into your drawing.  open a .pdf reader to check the scale.  on the "attach pdf underlay" window locate boxs that says scale.  if the drawing is a  1/4 inch scale uncheck the boxthat says specify on screen and type in 96.  if the the scale is 1/8 inch type in 48.  (the math is sound but if you disagree then feel free to check me) then move .pdf by means of a known point... 0,0,0  or a grid line that in on both your pdf and auto cad drawing.  for a scaned .pdf the scale my be very off. so be careful.
*Expert Elite*
1,589 Kudos
Post 6 of 8
08-03-2011 10:51 AM in reply to: tq1918
There is no PDF Overlay options in AutoCAD 2004/2005 where this old thread is located.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
9 Kudos
Post 7 of 8
08-03-2011 12:15 PM in reply to: tq1918
GUESS MY MATH WAS NOT SOUND IT IS 48 FOR 1/4 AND 96 FOR 1/8 SORRY
Valued Contributor
9 Kudos
Post 8 of 8
08-01-2012 06:57 AM in reply to: tq1918
Additionally you can scale your .pdf by reference.  It works just like rotate by reference.  Find four crossing intersections, two from the xrefed .pdf and two from known grid lines.  I use circles.
1.Place a circle of different color on each of the points (ex. Column A-1 grid red, A-1 .pdf yellow, Column J-10 grid green, Column J-10 .pdf cyan).
2. Place the .pdf A1 on A1 grid lines.
3. Type _SCALE enter then select the .pdf.  Select center of circle on A1 as base point.
4.  On command line select REFERENCE. Select same A1 base point again.
5. Then select cyan J-10 (from example) on .pdf
6. Then select green J-10 on grid lines.
If your .pdf is square with the world then it will now be fairly accurately place in your .dwg.
If your .pdf is not square with the world start over and use this same method with rotate by reference to make it plum level and square.
Post to the Community
New Post
