AutoCAD 2004/2005/2006
joeac
Message 1 of 6 (177 Views)
Paper space
177 Views, 5 Replies
12-18-2011 01:22 PM
How do I create a 24x18 sheet in paper space for "dwf's" enabling me to use the "publish" command?
*Expert Elite*
pendean
Message 2 of 6 (163 Views)
Re: Paper space
12-20-2011 03:24 PM in reply to: joeac
Is today your first time in AutoCAD? I ask so that anyone responding can tailor their responses correctly for your level of experience.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
joeac
Message 3 of 6 (155 Views)
Re: Paper space
12-21-2011 09:37 AM in reply to: joeac
No, I've been working w/ AutoCad for five or six years....
*Expert Elite*
pendean
Message 4 of 6 (152 Views)
Re: Paper space
12-21-2011 10:13 AM in reply to: joeac
Great: so, do you have an custom 24x18 paperspace Layout already created in your DWG file(s) ready to be published?
Or do you have an 24x18 paperspace Layout already defined in your master Template file?
Either can be set up for any plotter you have, even DWF plotter provided in R2006.
joeac
Message 5 of 6 (147 Views)
Re: Paper space
12-21-2011 03:11 PM in reply to: joeac
Dean, I' pulled down the Arch D (36x24) from Template, Architectural Imperial and it's okay; but when I got the Ansi C
Title Block, it scaled 22x17 not 24x18. Is there a way this can be adjusted to the correct size?
Joe
joeac
Message 6 of 6 (138 Views)
Re: Paper space
12-22-2011 09:31 AM in reply to: joeac
Dean, I finally figured it out and and now able to make any any sheet configuration with borders and title blocks that I need.
Needless to say, it's all written down in case there's a problem with memory. That's my memory! And if anyone else needs help with this, I can make the instruction sheet available. Later.........  Joe
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
