AutoCAD 2004/2005/2006
lygernight
Message 1 of 3 (188 Views)
Object Enablers for ACAD2k4 from 2k7 Architect
188 Views, 2 Replies
04-02-2008 08:21 AM
Ok help!
(now the stress is gone from screaming help)
I'm using a program called sprinkCAD N1 which is based on OEM AutoCAD2004. I have drawings which have objects from autocad architecture 2007 desktop so where do I download the object enablers?
If I go under the AutoCAd 2004 Enablers its for all software in 2004 and previous, and if I goto the 2007 it says it only applies to AutoCAD 2k7 and ACADLT 2k7 so which enablers do I need to get this to work?
I've downloaded both and to no avail, neither one will enable the objects to be viewable in acad 2k4 (OEM) so I'm lost.
Mostly its just walls thats are missing, and I can see them with 2008 TrueView but I need to be able to use my SprinkCAD program and see them there. Short of redrawing all the walls by scaling them from the paper drawings I have in hand I don't know what to do.
*Dean Saadallah
Message 2 of 3 (188 Views)
Re: Object Enablers for ACAD2k4 from 2k7 Architect
04-02-2008 10:12 AM in reply to: lygernight
OEs are version specific, each created for that AutoCAD flavor.
With OEM, you really do NOT have AutoCAD from Autodesk, what the OEs look
for as an application. You will need to contact your OEM reseller for
assistance or ask the file sender to Export To AutoCAD (remove AEC content)
for you to use.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
lygernight
Message 3 of 3 (188 Views)
04-03-2008 05:05 AM in reply to: lygernight
I will probably have to do the latter one because SprinkCAD's website sends me to autodesk's site for the object enablers.
...figures
Thanks.
