My software is corrupted and can get to my drawings anymore. System tells me to uninstall and re-install but I don't have the software with me now. Can someone please help me get through this since I am bored without it?
Fill it out and maybe paying for shipping.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18316170&linkID=9240617
Hi Samuel,
Unfortunately Autodesk only supports product versions up to three years past the current release. Therefore, the oldest media that we create is the 2011. We do have download links for some previous versions but we no longer manufacture 2005 discs or generate downloads that old.
Thanks for jumping in, Patchy! But I just wanted to clarify
If you have any questions about this please respond to this post.
Thank you!
Ebay, a few bucks and it has the CD
Welcome to the Autodesk Forums!
Did it just die today or something more going on?
Did you try a System Restore if the occurrence was today?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi again!
If you would like to purchase the media from an unauthorized distributor that is your choice, however it will not be Autodesk supported and we will be unable to assist with any issues caused by third party purchased media.
Also be sure that you are just buying the disc and not a license.
Good luck!
Correction, you can grab anything back to 2010 (today anyway):
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
1. Go to http://www.autodesk.com
2. Click on Contact Us at the bottom of the page
3. Click on Customer Service
4. Click on Virtual Agent “Ask”
5. Once the Virtual Agent window opens: Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
And I believe the suggestion above is to simply acquire a disk from ebay for the software: the assumption is the OP actually has there license number and other info saved somewhere safe instead of the product box they lost. Otgherwise the person that started this thread is up-the-creek-without-a-paddle and needs to find another CAD software to buy in LT is too expensive.
