AutoCAD 2004/2005/2006
*pwmarole
Message 1 of 5 (352 Views)
Migrate Custom Settings -problem
352 Views, 4 Replies
08-16-2004 10:01 AM
After installation of AutoCAD 2005 as an upgrade (from AutoCAD 2002) I can not run Migrate Custom Settings utility. The message box displayed is: "Migrate Profiles requires that AutoCAD 2000 or a later version be installed on your system" with OK button. There is still AutoCAD 2002 installed, I can run the program. Did somebody encounter same problem? Where to look for solution? Thanks in advance,
*Robert
Message 2 of 5 (352 Views)
Re: Migrate Custom Settings -problem
08-16-2004 10:17 AM in reply to: *pwmarole
I had problems migrating profiles from 2002/2004 to 2005. Silly things like "can't find the help file" and the like! In the end it was much less trouble to start from scratch and create new profiles in 2005. "pwmarole" wrote in message news:4120e986_3@newsprd01... > After installation of AutoCAD 2005 as an upgrade (from AutoCAD 2002) > I can not run Migrate Custom Settings utility. The message box displayed is: > "Migrate Profiles requires that AutoCAD 2000 or a later version be installed > on your system" > with OK button. > > There is still AutoCAD 2002 installed, I can run the program. > > Did somebody encounter same problem? Where to look for solution? > > Thanks in advance, > >
*Bud Schroeder [Autodesk Inc.]
Message 3 of 5 (352 Views)
08-16-2004 10:46 AM in reply to: *pwmarole
Hello, Can you tell me what version of 2002 you have? Is it AutoCAD 2002 and AutoCAD 2005 or something like AutoCAD ADT 2002 and AutoCAD 2005? The Migration Wizard is looking at the product ID to decide if you have a like product on your system. When they don't match up it won't migrate anything. Hope this helps. Bud Schroeder AutoCAD Test Development Autodesk Inc. "pwmarole" wrote in message news:4120e986_3@newsprd01... > After installation of AutoCAD 2005 as an upgrade (from AutoCAD 2002) > I can not run Migrate Custom Settings utility. The message box displayed is: > "Migrate Profiles requires that AutoCAD 2000 or a later version be installed > on your system" > with OK button. > > There is still AutoCAD 2002 installed, I can run the program. > > Did somebody encounter same problem? Where to look for solution? > > Thanks in advance, > >
*Tom Parks
Message 4 of 5 (352 Views)
08-16-2004 01:54 PM in reply to: *pwmarole
I had problems migrating from 2000i to 2005. My design center kept looking to 2000i for certain DLL files etc, and would not open. Decided not to use the migration tools when upgrading the other office workstations. "pwmarole" wrote in message news:4120e986_3@newsprd01... > After installation of AutoCAD 2005 as an upgrade (from AutoCAD 2002) > I can not run Migrate Custom Settings utility. The message box displayed is: > "Migrate Profiles requires that AutoCAD 2000 or a later version be installed > on your system" > with OK button. > > There is still AutoCAD 2002 installed, I can run the program. > > Did somebody encounter same problem? Where to look for solution? > > Thanks in advance, > >
New Member
T-YACHTS
Message 5 of 5 (352 Views)
08-19-2004 12:09 PM in reply to: *pwmarole
I have been having similar problems. We are running 2000i and have crossgrades for MECH 2005. I have yet to see the "Migrate Custom Settings" program upon first run of new MECH 2005. I have found the "ADMigrator.exe" file, but when I try to run it manually it give me the same message you have received...
Also, from our understanding, the new install should be "side-by-side" with ACAD 2000i. When I "Activate" the new MECH 2005, 2000i is no longer usable??? This causes a problem since we are running another piece of software that, until it gets upgraded, needs ACAD 2000i to run...
Any help is GREATLY appreciated...
Announcements
Need installation help?
