AutoCAD 2004/2005/2006
*Hislop, Cory
Message 1 of 10 (680 Views)
metric scaling...
680 Views, 9 Replies
09-02-2003 01:46 AM
1:100 = 10xp
1:200 = 5xp
1:250 = 4xp
1:500 = 2xp
how do I figure out the scale factors for 1:300 & 1:400
*GaryB
Message 2 of 10 (680 Views)
Re: metric scaling...
09-02-2003 01:51 AM in reply to: *Hislop, Cory
It looks as though you are drafting in metres and plotting on sheets
measured in millimetres, that's how we do it too. Hence, 1:300 = 3.3333xp
and 1:400 = 2.5xp. You can do this yourself for any scale by using the
formula: 1000/(desired scale) = zoomfactor(xp).
"Cory Hislop" wrote in message
news:9F76109D3A0F1EB06838493022E1D385@in.WebX.maYIadrTaRb...
> 1:100 = 10xp
> 1:200 = 5xp
> 1:250 = 4xp
> 1:500 = 2xp
*Hislop, Cory
Message 3 of 10 (680 Views)
Re:
09-02-2003 01:57 AM in reply to: *Hislop, Cory
ok I must be doing something wrong here.... I go into tile mode.. hit "Z"
then enter.. then "S" and enter... then I would normally put 1/(scale
factor)xp.. for some reason its not letting me put a decimal in there.
"GaryB" wrote in message
news:FBE3A6275942E186C7FD758E6ABC6B25@in.WebX.maYIadrTaRb...
> > 1:100 = 10xp
> > 1:200 = 5xp
> > 1:250 = 4xp
> > 1:500 = 2xp
*ffejgreb
Message 4 of 10 (680 Views)
Re:
Why don't you use the Viewport toolbar and just enter the scale factor
(1:300 or 1:400) you want in the drop down?
*GaryB
Message 5 of 10 (680 Views)
Re:
09-02-2003 02:05 AM in reply to: *Hislop, Cory
In your Layout tab type MSPACE enter ZOOM enter 3.3333xp enter, and you
should be done. That is assuming I deciphered your original post correctly.
news:9690F1542E6EFDCD5B4E64E87E16C267@in.WebX.maYIadrTaRb...
"Z"
3.3333xp
> > > 1:100 = 10xp
> > > 1:200 = 5xp
> > > 1:250 = 4xp
> > > 1:500 = 2xp
*Palme, Jürgen
Message 6 of 10 (680 Views)
Re:
09-02-2003 02:19 AM in reply to: *Hislop, Cory
> > 1:100 = 10xp (= 1000/100)
> > 1:200 = 5xp (= 1000/200)
> > 1:250 = 4xp (= 1000/250)
> > 1:500 = 2xp (= 1000/500)
1:300 -> 10/3xp (= 1000/300)
1:400 -> 10/4xp (= 1000/400)
Juergen
> > 1:100 = 10xp
> > 1:200 = 5xp
> > 1:250 = 4xp
> > 1:500 = 2xp
*Palme, Jürgen
Message 7 of 10 (680 Views)
Re:
If you want to write 1/scalefactor the scalefactor MUST be an integer
value. This is a known limitation of this kind of notation of a
quotient. You must not write e.g 1/2.5, but 10/25 and so on.
Juergen
*Alexander, Dave
Message 8 of 10 (680 Views)
09-02-2003 02:45 AM in reply to: *Hislop, Cory
If you use 1/100xp or 1/300xp or 1/200xp, you don't care if it is 10xp or
whatever.
Dave Alexander
> 1:100 = 10xp
> 1:200 = 5xp
> 1:250 = 4xp
> 1:500 = 2xp
*Pehrsson, Jim
Message 9 of 10 (680 Views)
Re:
09-03-2003 01:10 PM in reply to: *Hislop, Cory
I draft in both metres (meters) and millimetres so I need something simple
so I won't tax my brain.
When drafting in metres I use say 1000/300xp as my base unit is 1000mm
long
When drafting in mm I use 1/300xp as my base unit is 1mm long
both viewports will are 1:300. Note no decimals & no thinking
Jim Pehrsson
"Dave Alexander" wrote in message
news:2673356CD68441CB1E5EBBE90EF364B3@in.WebX.maYIadrTaRb...
> whatever.
> Dave Alexander
*Alexander, Dave
Message 10 of 10 (680 Views)
Re:
09-03-2003 11:41 PM in reply to: *Hislop, Cory
Same here, sort of....
Our metric base is 1mm and as you say for layout tab plotting at 1:1, we use
1/100xp for view ports at a scale of 1:100.
We also deal with civil drawings where the base unit is 1 meter and one
drawing unit = 1 meter. To be honest, I haven't really looked at their plot
drawings to see if the layout tab is based on one drawing unit = 1 meter or
1 drawing unit = 1mm.
Dave Alexander
"Jim Pehrsson" wrote in message
news:128AB1CF6068B2DFFEBD29ED12A2BC9F@in.WebX.maYIadrTaRb...
> long
long
> Jim Pehrsson
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
