AutoCAD Forum
Linked field from Block Properties table to attribute
3 REPLIES 3
674 Views, 3 Replies
Hi
Not sure if this is possible or whether there maybe an easier way to achieve the same result. I have produced a dynamic block with  block properties which contains a rectangle 700mm deep x 250mm wide rising up in 50mm increments to 2000mm.  Each increment/size has its own manufacturing reference code. Is there a way to link the chosen size lets say 700mm x 2000mm to a attribute tag named size so when I exract the data to excel it states the correct size selected? rather than having to do it manually in the properties box.
I attach a drawing which may help explain better
Many thanks
3 REPLIES 3
cbuchert
I have the same question, but for a series of wide flange blocks I've put together. I know you can do this with visibility states.
I have the same question as yours. I'm looking at the forum but I have find nothing until now. I hope that somebody will help us 😉
in reply to: cbuchert
Visibility state wont help me as my blocks are already very complicated and to produce these 4 times as a visibility would be extremely differicult.
”Boost
