AutoCAD 2004/2005/2006
*Bill Warner
Post 1 of 4
Layer Manager will not open Unhandled Exception.
369 Views, 3 Replies
03-26-2005 07:29 PM
My layer manager will not open, When I select it I get a Diaglog Box that states An Unhandled Exception has occured in your application. Click Continue and application will ignore this error and attempt to continue. Execption Has been thrown by target of an invocation." There are two buttons, Details and Continue. I click on Continue and continue working without by the layermanager. I am running XP Pro SP2 AC05 SP1. Thanks for your help ! Bill When the Details Button is pushed the window displays the following: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for "System.Windows.Forms.DataGrid" threw an exception. ---> System.ArithmeticException: Overflow or underflow in the arithmetic operation. at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont) at System.Drawing.Font..ctor(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont) at System.Windows.Forms.ControlPaint.FontInPoints(Font font) at System.Windows.Forms.Control.get_DefaultFont() at System.Windows.Forms.DataGrid..cctor() --- End of inner exception stack trace --- at System.Windows.Forms.DataGrid..ctor() at Autodesk.AutoCAD.LayerManager.BaseGrid..ctor() at Autodesk.AutoCAD.LayerManager.LayerGrid..ctor() at Autodesk.AutoCAD.LayerManager.MainForm.InitializeComponent() at Autodesk.AutoCAD.LayerManager.MainForm..ctor() at Autodesk.AutoCAD.LayerManager.MainForm.RunForm(IWin32Window owner, Database db) at Autodesk.AutoCAD.LayerManager.Commands.Layer() --- End of inner exception stack trace --- at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess) at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at AcMgPerDocumentCommandClass.Invoke(AcMgPerDocumentCommandClass* , gcroot<:REFLECTION::METHODINFO __gc="">* mi) at AcMgCommandClass.CommandThunk.Invoke(CommandThunk* ) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll ---------------------------------------- acdbmgdhost Assembly Version: 16.1.63.0 Win32 Version: 16.1.63.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202005/AcdbMgdHost.DLL ---------------------------------------- acdbmgd Assembly Version: 16.1.84.0 Win32 Version: 16.1.84.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202005/acdbmgd.dll ---------------------------------------- acmgd Assembly Version: 16.1.84.0 Win32 Version: 16.1.84.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202005/acmgd.dll ---------------------------------------- System Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- System.Xml Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System.Drawing Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- AcLayer Assembly Version: 16.1.84.0 Win32 Version: 16.1.84.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202005/AcLayer.DLL ---------------------------------------- AcLayer.resources Assembly Version: 16.1.63.0 Win32 Version: 16.1.63.0 CodeBase: file:///C:/Program%20Files/AutoCAD%202005/en-US/AcLayer.resources.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
Distinguished Contributor
0 Kudos
Post 2 of 4
Re: Layer Manager will not open Unhandled Exception.
07-29-2005 06:29 AM in reply to: *Bill Warner
Exacly the same error occure with me!!!
Does anyone can help us please?
3 Kudos
Post 3 of 4
06-28-2006 10:49 AM in reply to: *Bill Warner
Did you guys ever find a solution for this?
Thanks.
*Dave Drahn
Post 4 of 4
06-28-2006 02:09 PM in reply to: *Bill Warner
Nevermind: I installed WebEx for something the other day and that must've
install .NET 2.0 - Seems it and 2006 SP1 don't like each other much.
Uninstalled that, repaired acad and we're GTG.
wrote in message news:5221892@discussion.autodesk.com...
Thanks.
