AutoCAD 2004/2005/2006
Valued Contributor
pherridge
Message 1 of 6 (11,900 Views)
keystrokes for squared symbol
11900 Views, 5 Replies
11-30-2003 12:27 PM
For those familiar with the micro and helv AutoCad fonts, what are the keystrokes for inserting a 2 above and to the right of a letter to denote 'squared', as in square metres?
*Craig
Message 2 of 6 (11,900 Views)
Re: keystrokes for squared symbol
11-30-2003 12:44 PM in reply to: pherridge
Alt+0178
Press & hold the Alt Key then press 0,1,7,8 on
the numeric keypad then release the Alt key.
cubed ³ (Alt+0179)
plus/minus ± (Alt+0177)
degrees ° (Alt+0176)
diameter ø (Alt+0248)
copyright © (Alt+0169)
registered ® (Alt+0174)
quarter ¼ (Alt+0188)
half ½ (Alt+0189)
three quarter ¾ (Alt+0190)
these may or maynot work with all
fonts
Craig
For
in square metres?
Valued Contributor
pherridge
Message 3 of 6 (11,900 Views)
Re:
11-30-2003 12:59 PM in reply to: pherridge
Thanks for your prompt response Craig
*Craig
Message 4 of 6 (11,900 Views)
Re:
11-30-2003 03:41 PM in reply to: pherridge
your welcome
*Expert Elite*
scot-65
Message 5 of 6 (11,900 Views)
12-01-2003 05:59 AM in reply to: pherridge
Pherridge,
You may also try the following:
Diameter = % % C or % % 129 or % % 174
Degrees = % % D or % % 127 or % % 160
Overscore = % % O
Plus/Minus = % % P or % % 128 or % % 153
Underline = % % U
Centerline = % % 130
Property Line (PL) = % % 131
Copyright = % % 147
Triangle = % % 148
Angle = % % 158
Square Foot = % % 159
Flood Line? (FL) = % % 161
Greater and Equal = % % 162
Less and Equal = % % 166
No spaces between characters...
(I added spaces just in case HTML evaluates as an expression...)
As with Craig, the fonts you use may not support some or all of these extended characters...
Additional extended characters can be found in any programmers Appendecies
as "ASCII" characters...
Scot-65
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
Active Contributor
goodjuju
Message 6 of 6 (11,900 Views)
08-22-2005 08:16 AM in reply to: pherridge
Some fonts do not support the ALT+xxx keyins, so I find a convenient way to get the 'squared' symbol for example is to enter the character, followed by the ^ symbol and then stack the imaginary fraction. ie 10x102^ will give 10x10 and the squared symbol.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
