AutoCAD 2004/2005/2006
Distinguished Contributor
cadee
Message 1 of 5 (218 Views)
Inverted linetype
218 Views, 4 Replies
01-11-2006 07:03 AM
I've created a linetype which show the wording 40A BUSBAR within the line, but some reason the wording becomes inverted and the words and does show properly within the gap of the line.
Can anyone help on why its doing this and how to stop it.
Thanks in advance.
enrique r
Message 2 of 5 (218 Views)
Re: Inverted linetype
01-11-2006 07:16 AM in reply to: cadee
you can try rotating the line you draw from the mid point 180 to change the direction, and the position of the text depends on the values you used to define it S, R, X and Y.
*Adam Wuellner
Message 3 of 5 (218 Views)
01-11-2006 07:36 AM in reply to: cadee
The size of the text is also affected by the settings for the text style
that the linetype references.
New Member
IGA001
Message 4 of 5 (179 Views)
10-22-2012 05:52 AM in reply to: cadee
use "reverse" command
*Expert Elite*
Kent1Cooper
Message 5 of 5 (163 Views)
11-06-2012 08:40 AM in reply to: IGA001
For those with older versions that don't have Reverse [such as 2004 in this Discussion Group area], you can use:
http://cadtips.cadalyst.com/object-properties/reverse-entity-direction
And even for those who do have Reverse, the routine in the link works with more entity types than Reverse does.
Kent Cooper
Post to the Community
New Post
Need installation help?
