AutoCAD 2004/2005/2006
frank.balnius
Message 1 of 5 (1,337 Views)
import DWF into DWG
1337 Views, 4 Replies
12-05-2005 01:36 PM
Is there a way to import/attach DWF files into DWG files as a type of underlayment that you could draw on top of, dimension to, and snap to lines?
*R.K. McSwain
Message 2 of 5 (1,337 Views)
Re: import DWF into DWG
12-05-2005 01:43 PM in reply to: frank.balnius
fbalnius said the following on 12/5/2005 3:36 PM:
Use "Markup Set Manager" on the Tools menu
See also:
http://autodesk.blogs.com/between_the_lines/2004/05/work_flow_and_m.html
R.K. McSwain
http://rkmcswain.blogspot.com
*Dean Saadallah
Message 3 of 5 (1,337 Views)
12-05-2005 02:44 PM in reply to: frank.balnius
No.
It's a wishlist item, maybe it will show up in R2007 or
R2008: I think that's probably the next logical step for the
format, being able to xref or Insert DWF files.
If you just want to markup or redline a DWF, you need to buy
DWFComposer, another software package from Autodesk (or
other 3rd party software that do the same). Check it out at
http://www.autodesk.com/products
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
frank.balnius
Message 4 of 5 (1,337 Views)
12-06-2005 06:44 AM in reply to: frank.balnius
Thanks Dean.
I think you're right. It seems like the ability to import DWFs should be a no-brainer. So I guess we wait.
Member
Jeff2006
Message 5 of 5 (1,337 Views)
03-19-2006 06:05 PM in reply to: frank.balnius
This program may help you:
DWF Importer
http://www.autodwg.com/dwf_dwg_converter/
DWF Importer(DWF to DWG Converter) is an AutoCAD AddIn help you import DWF file into AutoCAD, it supports AutoCAD 2006, 2005, 2004, 2000/2000i and R14.
Announcements
Need installation help?
