AutoCAD 2004/2005/2006
Member
Mawnster
Message 1 of 5 (1,829 Views)
how to delete hidden objects on defpoints
1829 Views, 4 Replies
05-19-2009 02:42 PM
I have a drawing that has hidden objects on defpoints layer. I turn all layers on and thaw them all but when hit ctrl+a there appear to be snap points that belong to hidden objects. when I cross window in the area I find nothing. how do you turn these and how do you delete them? Edited by: Mawnster on May 19, 2009 9:44 PM
Valued Contributor
tom_kelly
Message 2 of 5 (1,829 Views)
Re: how to delete hidden objects on defpoints
05-19-2009 09:54 PM in reply to: Mawnster
If you don't want to see the snap points of the hidden objects which are on a specific layer, then inspite of turning off the layer, freeze it.
Hope this may help you.
Tom Kelly
www.indovance.com
*Gordon Stephens
Message 3 of 5 (1,829 Views)
05-20-2009 12:30 AM in reply to: Mawnster
Dimension end points are found on the defpoints layer. Also, pressing
Ctrl-A shows everything gripped, so could they be block inserts that happen
to be remote from the blocks themselves?
Gordon
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
2009 9:44 PM
Member
1GuyG
Message 4 of 5 (1,576 Views)
12-16-2011 08:12 AM in reply to: Mawnster
Write out everything to a block from Model space, then paper space; open a new drawing; insert blocks and overwrite old drawing.  That's the way to delete things you can't see.
Valued Contributor
slant
Message 5 of 5 (1,562 Views)
12-21-2011 01:35 PM in reply to: 1GuyG
i type "erase", then "all" for select objects.  then i deselect all visible objects and hit enter.  anything in the drawing that you can't select is erased.   then i purge and audit and qsave. this works for invisible blocks and off layers, so excercise caution.
