Greetings,
I am using MTEXT and a field to show the location of my drawings when plotted for any future reference.
Currently, it shows the server name on my drawing at the beginning. IE: \\SERVER\........
Is there any way to eliminate that portion of the Filename field?
Current field expression is %<\AcVar Filename \f "%tc1%fn7">%
(which, I'm afraid, I have no clue what it means).
Thanks!
Open your Field to the editor.
Do you have the options for Filename only, Path only, and Path and Filename?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Likely no since the Server is part of the Path.
The answer is in this screenshot for the Fielname variety:
Read The Swamp response a the top of this Google search.
I am not sure you can.
Do you know your way to the Customizations Forum? They may know over there.
