AutoCAD 2004/2005/2006
New Member
jmarquez
Message 1 of 7 (1,133 Views)
fail to get Comm Cntr Controller
1133 Views, 6 Replies
06-21-2005 04:47 PM
This happens when im loading AutoCAD. It stays there sitting until a dialog says "fail to get Comm Cntr Controller" and then it loads.
*Walt Engle
Message 2 of 7 (1,133 Views)
Re: fail to get Comm Cntr Controller
06-21-2005 05:11 PM in reply to: jmarquez
If you have used a registry cleaner, it will wipe out registry of commcntr. You will have to reinstall autocad.
Member
giorgioferrari
Message 3 of 7 (1,133 Views)
03-10-2006 12:10 PM in reply to: jmarquez
Hi have the same problem. And I have reinstalled AutoCAD at least three times, but I still have the problem. What can I do? It is neccessary to reinstall Windows XP to fix this Autodesk problem?
Any hints would be welcome!
Thank you very much.
giorgioferrari
*None
Message 4 of 7 (1,133 Views)
03-10-2006 01:06 PM in reply to: jmarquez
I would not think it necessary to re-install XP. Do you have Service
Pack 2? Other than this, I don't have any idea why you cannot connect to
CommCntr. Have you tried HELP?
I am running 2006 and just connected to CommCntr without any problems. I
am aware that this doesn't help your situation, but was just checking to
make sure autodesk's server is available - and it is!
Member
giorgioferrari
Message 5 of 7 (1,133 Views)
03-14-2006 01:02 AM in reply to: jmarquez
After your hint I have uninstalled AutoCAD LT 2004, installed Windows XP SP2 and then installed again AutoCAD LT 2004, but I still have the same problem. Any other idea?
Active Contributor
bmyers
Message 6 of 7 (1,133 Views)
05-16-2006 07:25 AM in reply to: jmarquez
If you have a newer version of AutoCAD (2006 or 2007) then you have an option.
See this thread: http://discussion.autodesk.com/thread.jspa?messageID=4971894
If its an older version then I believe there is a Registry change you can make, you can likely find it here in these discussion groups with a quick search...
Brian Myers
Sr Applications Engineer - Autodesk Revit Architecture Certified Instructor (ACI)
Seiler Instrument, St Louis MO
Member
giorgioferrari
Message 7 of 7 (1,133 Views)
05-30-2006 12:58 AM in reply to: jmarquez
Hi, thank you for your answer.
I have solved my problem following instructions onto following thread
http://discussion.autodesk.com/thread.jspa?messageID=4167107
renaming the two specified files into thins thread make everything working perfectly!
Announcements
Need installation help?
