AutoCAD 2004/2005/2006
Active Contributor
0 Kudos
Post 1 of 7
Fail to create CommCntrClientSink object!
3262 Views, 6 Replies
03-22-2005 08:18 AM
I get this message when I try to run acad 2004 while Outlook 2003 is open. anyone?
Re: Fail to create CommCntrClientSink object!
03-22-2005 10:44 AM in reply to: mckishen
most likely a damaged DLL file. Try to "repair" your installation first, then if that's not successful, a new install and registry cleanup may be necessary. "mckishen" wrote in message news:20660515.1111508320860.JavaMail.jive@jiveforum1.autodesk.com... > Fail to create CommCntrClientSink object! > > I get this message when I try to run acad 2004 while Outlook 2003 is open. > anyone?
*Walt Engle
Post 3 of 7
03-22-2005 11:46 AM in reply to: mckishen
Did you use a registry cleaning tool? Autodesk advises that using a tool for cleaning the registry will wipe out the registry for CommCentr and you will "have to re-install autocad".
Active Member
0 Kudos
Post 4 of 7
10-03-2006 04:45 PM in reply to: mckishen
Hi All
I had this problem and I have norton system works clean up, I just ticked all the boxes in the history panel and undid the registry fixes, and wala it was working again
Member
0 Kudos
Post 5 of 7
02-08-2007 09:11 AM in reply to: mckishen
We had this problem on autocad 2007 also.
Our solution - make sure you disable any virus protection before you install autocad.
New Member
0 Kudos
Post 6 of 7
03-23-2007 09:03 AM in reply to: mckishen
A piece of advise....
Microsoft windows offer a system analysis an dregistry cleanup tool on their website, this tool will can this problem to occur... do not use it....
New Member
0 Kudos
Post 7 of 7
08-08-2012 08:46 AM in reply to: mckishen
This is a Registry error. Registry cleaners cause it. You do not have to reinstall autocad 2007. You can if you want but you only have a limited amout of times you can install or reinstall the program. It is better when you get this error to go into c:/programfiles/autocad 2007 and if the folders for the registry backup and open them and merge the backups back to you computer registry
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
