AutoCAD 2004/2005/2006
Member
CUNCON
Message 1 of 12 (169 Views)
EXTRUDE A TEXT
169 Views, 11 Replies
08-14-2006 01:32 AM
I'm using AutoCAD2006 and I want to extrude a text but I don't have "txtexpress tool".Could you tell me how to make it.Thanks a lot.
*Expert Elite*
JDMather
Message 2 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-14-2006 04:42 AM in reply to: CUNCON
I don't have that tool either and have never heard of it. The most obvious thing I can think of is to put the installation disk in your optical drive and install the express tools and read the express tools help. Alternatively you could create your one polyline letters if there aren't too many needed.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Distinguished Contributor
teiarch
Message 3 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-14-2006 05:27 AM in reply to: CUNCON
If the text is an SHX font, you can give it thickness.....
*Dean Saadallah
Message 4 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-14-2006 05:59 AM in reply to: CUNCON
txtexpress tool? Do you mean you just have not gotten around
to installing Express Tools yet from the product CD and want
to use TXTEXP command?
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
madcadd
Message 5 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-14-2006 07:48 AM in reply to: CUNCON
Hi CUN,
See attached dwg. I made the upper case letters and numerals a while back when I needed them. I haven't needed the lower case and have never converted them. But you are welcome to these. Message was edited by: Discussion Admin
Member
CUNCON
Message 6 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-14-2006 09:02 PM in reply to: CUNCON
Hi!JD Mather,
I thought I'd forgotten chosing "full" while installation processing but now everything is okay!thank you very much for your help.
Member
CUNCON
Message 7 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-14-2006 09:19 PM in reply to: CUNCON
Hi! madcadd,
My problem's solved.Thank you very much for your acad file.
*Expert Elite*
JDMather
Message 8 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-15-2006 04:32 AM in reply to: CUNCON
Educate me! Message was edited by: Discussion Admin
ladonna101
Message 9 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-15-2006 06:22 AM in reply to: CUNCON
Probably because there is no txtexpress. She was looking for text explode (txtexp). I'd make sure I was reading things correctly before I started making fun of other people. Don't you look silly. Message was edited by: Discussion Admin
madcadd
Message 10 of 12 (169 Views)
Re: EXTRUDE A TEXT
08-15-2006 08:13 AM in reply to: CUNCON
Reply From: teiarch
Date: Aug/14/06 - 07:27 (CDT)
Re: EXTRUDE A TEXT
Apparently you didn't know about txtexp either huh teiarch? So investigate it now that you do. And now you can really make some hot fonts for everybody.
And the only thing giving font thickness is good for that I've found is to make it disappear when it is behind a solid.
Announcements
Need installation help?
