I need to embed the files that are refernced in a drawing into the actual drawing. That way, if the path is broken they will still be visible.
I know this will make the drawing larger, but that really isn't an issue. The referenced file is a mrSid and I am using Autocad Map 2015 with the Carlson Civil Suite addon.
Solved by pendean. Go to Solution.
XREF, Bind option. You are aware, I hope, that once you Bind an Xref in, it will no longer update if the source drawing is changed, as it will if you don't Bind it.
Hello
+1 with Kent
If the default BIND option is not OK for you,
please change the System variable BINDTYPE ...
Patrice BRAUD
Hello!
For some reason, I can't bind the Mr. Sid files. It is not that they don't work, but that the Bind command just isn't there.
What would I change the BINDTYPE to?
@rogersmi87 wrote:
I did say it was a mrSid file in the original post.
[... which I didn't recognize as a file type, being unfamiliar with the designation and whatever makes them.]
Hello
Sorry I have "followed" Kent so I have not understood you were speaking only about .SID (or .ECW) raster files !
Happy New Year and THE HEALTH, Regards, Patrice
Patrice BRAUD
