Hy All!
I use AutoCAD 2006 to create my drawings. I save it in DWG format 2000. My coworkers can open my drawings only in DWG Trueview 2013 or 2012. If they do so, they see all the frames from the blocks. In AutoCAD 2006 they don't show up.
This is the drawing in True view:
This is the same DWG in AutoCAD2006:
My question is, how can i turn these frames off???
Greetings from Hungary,
Tothgra
This are XCPILFRAMES. And i set them, in AutoCAD OFF. Then when somebody opens the file in DWG TrueView the XCLIPFRAMES shows up again. It is an anoying problem, but i found the solution. I must save my drawings in DWG 2004 and the XCLIPFAMES are gone.
